Old 05-07-2004, 04:53 AM   #1
Jamez_Warner
Angry Shield your lilliput !!
After finishing my carpc and everything working ,I got out of the car - no central locking - DAMNIT ! what have I done, I see pc shut off and try again - it's fine. OK so its the PC ? tried everything unplugging ignition leads to opus unplugging amps - all sorts. The only thing that made any difference was unplugging the TFT. this got me thinking - my lilli is uncased and mounted in the dash - I tried central locking with lilli out of dash it was fine.
I'm gonna need to shield the backlight inverter tonight....
hoping this encounter might help other people with similar symptoms !
www.digital-car.co.uk - The UK CarPC Forum
Jamez_Warner is offline   Reply With Quote
Advertisement Sponsored links
Old 05-07-2004, 05:04 AM   #2
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
Ah, I've noticed this a few times but it doesn't do it every time!
If I stand there watching the screen and repeatedly pressing the button, as soon as the screen goes off, the central locking works! Like I said, not every time though, Strange.
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 05-07-2004, 05:14 AM   #3
masch
Interesting. Everyone on this thread mounted the screen in dash without using an external housing?
Do you think the backlight inverter is the cause?
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 05-07-2004, 05:17 AM   #4
NovaKane is on a distinguished road
is the backlight inverter high AC voltage, because that would make sense. AC voltage, causes magnetic flux...and so on and so forth.
NovaKane is offline   Reply With Quote
Old 05-07-2004, 05:20 AM   #5
webnosis is on a distinguished road
Back to the Future
Magnetic flux huh! Maybe we should install Flux-Capacitors in our cars to combat the problem...
Sorry, couldn't resist...
webnosis is offline   Reply With Quote
Old 05-07-2004, 05:27 AM   #6
pioneer is on a distinguished road
Inverters for backlights are high voltage AC. i think that the plastic case on the touch screens have a metal coating on the inside to stop interferance, removing the back means that there is no shilding and the high freq AC interfears.
one thing to try is locking the car with the key in the lock, no with the keyfob, if it works like that then the screen is producing radio waves that are gamming the signal from the keyfob.
a bit of mettal that is grounded to the 0v line should combat the interference.
pioneer is offline   Reply With Quote
Old 05-07-2004, 05:27 AM   #7
Raw Wave
Laidback's Avatar
Mine's not mounted in-dash
Laidback
Laidback Carputer
Old 05-07-2004, 05:32 AM   #8
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Everyone one on this thread? prior to your post, 2 people had replied, although technically correct it's not that interesting. Now if there had been 10-15 replies that would have been interesting.
Oh! and subsequently we find out only half of the people who had replied had actually mounted it in dash.
Enforcer is offline   Reply With Quote
Old 05-07-2004, 05:43 AM   #9
Jamez_Warner
I think its most likely to be the invertor - thinking about it around 3000V of AC unshielded power near car electronics is always a bad idea - I'm wondering whether a layer of foil backed paper soldered to ground around the back would sort this... ( im not shielding expert )
I'm assuming there is a metallic aspect to the "plastic" stock housing
Old 05-07-2004, 05:47 AM   #10
masch
Enforcer : ooh a nitpicker =P
I didnt mount mine, I used a TM701-L case. I've never had this problem before. But then, the car pc is never on if I'm about to lock/unlock it. Are the guys having this problem using a delayed shutdown controller or something?
Old 05-07-2004, 05:50 AM   #11
Jamez_Warner: foil should work, just make sure its grounded. also a good idea to make sure it don't short anything out
Old 05-07-2004, 05:54 AM   #12
Jamez_Warner
masch - pc takes around 10 secs for opus to power it down, it's during this time locking is unavaliable... my lilliput is powered from opus so its not off until PC is, if you used a cig lighter power you wouldn't see the effect.
If it can do this to your central locking - I hate to think how its effecting ABS + airbags - It needs sorting
James
Old 05-07-2004, 05:55 AM   #13
Raw Wave
Laidback's Avatar
Yeah, windows shutdown! Mine take's about 12 secs to hibernate after pulling the key out, by that time I'm out of the car and (sometimes) wondering why the doors aren't locking...
Laidback
Laidback Carputer
Old 05-07-2004, 06:01 AM   #14
Jamez_Warner
i'll let you know how i get on with the shielding - this might be cause of your probs too laidback...
Old 05-07-2004, 08:25 AM   #15
beaverpants is on a distinguished road
how did you wire the opus to your battery. do you have a volt meater conected anyware in your car. maybe with the engin off. the opus darw's so mutch power that thare isnt enuf to push the solinodes and lock the car??
beaverpants is offline   Reply With Quote
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Writeup Lilliput installation in TM-701L housing spyhunter LCD/Display 65 05-17-2004 07:58 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
