The MP3car.com Store
Thread Tools Display Modes
Old 05-13-2004, 02:29 AM   #16
eCar™'s Avatar
Vehicle: '03 Ford Taurus SES
My Photos: (0)
Ryuandwings, do you still have the schematic I drew up for this? Another member PMed me about it, but I can't seem to find it.
If you have it, post it here.
Maybe post your pics of the circuit board (where the switch is removed from), too.
eCar™ is offline   Reply With Quote
Sponsored Links
Old 05-13-2004, 06:51 AM   #17
ryuandwings's Avatar
Vehicle: 2007 Subaru Outback
My Photos: (0)
Here is the schematic you sent me.
I'm still looking for the ciruit board. I will post as soo as I find it.
ryuandwings is offline   Reply With Quote
Old 05-13-2004, 07:06 AM   #18
My Photos: (0)
I found them.
The Cheese Box as you receive it.
Circut board of Cheese Box with swtich. Round breen thing is the switch.
Here is back of circuit board. 6 pins you see toward corner is the switch.
And this is what is looks like when switch is desoldered.
I hope this helps.
Old 05-13-2004, 08:45 AM   #19
eCar™'s Avatar
My Photos: (0)
You might want to use a SPDT switch (ON/OFF/ON), like in this schematic. That way you can switch to composite anytime (reverse or not), leave the VGA passthrough all the time (reverse or not), or have it switch automatically with the reverse lights.
Old 05-13-2004, 09:40 AM   #20
My Photos: (0)
Maybe this can be of intrest?
http://www.ramelectronics.net/html/u...o_adapter.html
Video to USB converter
Flapp is offline   Reply With Quote
Sponsored Links
Old 05-13-2004, 11:11 AM   #21
My Photos: (0)
What about using a webcam? you can get some good quality ones now.
pioneer is offline   Reply With Quote
Old 05-15-2004, 11:49 PM   #22
Registered User
aoLhaTer's Avatar
Vehicle: 04 Infiniti G35 Coupe
My Photos: (0)
only problem witha webcam or any other type of digital computer input is that you still need some method of triggering the camera action automatically by the reverse lights
i like eCars method
thanks for the schematic
my electronics know how is limited so i must ask this question, what do the little numbers mean?
aoLhaTer is offline   Reply With Quote
Old 05-17-2004, 09:23 AM   #23
My Photos: (0)
i like eCars method
That little numbers indicating each pin where you connect wires. Same numbers are labled on relays. That should help you wire up everything.
Old 05-17-2004, 03:12 PM   #24
Registered User
aoLhaTer's Avatar
My Photos: (0)
i think im even more lost now
what does the bigger blue box represent?
Old 05-17-2004, 03:19 PM   #25
My Photos: (0)
On the second schmatic, bottom blue box is a relay which is triggered by reverse light. So camera is to be diplayed when shifted to rear.
Top blue box is a manual switch.
It will have three settings, Auto, VGA, VIDEO.
Did it help?
Old 05-17-2004, 03:21 PM   #26
Registered User
aoLhaTer's Avatar
My Photos: (0)
Im not really understanding what the relay actually is
Excuse my ignorance
Old 05-17-2004, 03:32 PM   #27
eCar™'s Avatar
My Photos: (0)
The bigger blue box is a SPDT relay. That stands for "Single Pole, Double Throw". Click here if you need to know how a relay works.
Look for a very small relay. The load (CheeseBox) is very small; probably much less than 1A. In general, the smaller the rated load of the relay, the less current it will need for the trigger (to activate the coil and make the switch). This would be especially important if you have a car that can detect burnt out reverse bulbs. I'm not even sure that you could find a relay that will work without triggering a burnt bulb signal in those cars. By adding the relay, you change the resistance/current in the reverse lamp circuit of the car. A smaller relay will minimize the change, though.
Old 05-17-2004, 03:33 PM   #28
My Photos: (0)
Excuse my ignorance
I guess you can think relay as automatic switch when it get some signal.
In this case, when the relay get power from reverse light (which only turns on when shifted rear), circuit is switched to 87 instead of 87a.
When power is off, relay is at the 87a position and that makes Cheese box circuit open. When relay gets power, it switche to 87 and that makes cheese box closed.
FYI, when cheese box is open, VGA is displayed on the monitor and when it is closed VIDEO is displayed.
Old 05-17-2004, 03:36 PM   #29
Registered User
aoLhaTer's Avatar
My Photos: (0)
ah! thanks for the explanation guys
this would do the trick right
http://www.radioshack.com/product.as...5Fid=275%2D005
and the black line triangle at the bottom is ground feed right?
Old 05-17-2004, 04:00 PM   #30
eCar™'s Avatar
My Photos: (0)
Yeah, but you'd also need a resistor to drop the voltage to the 7-9VDC that relay needs. Look for a 12VDC one.
If possible, skip Radio Shack. They are the worst. I refuse to buy anything from them, and encourage others to boycott them also.
Sponsored Links
vB code is On
Trackbacks are Off
Auto reverse camera Tha Hombre General Hardware Discussion 27 04-10-2006 02:28 PM
(Div)XBox Carputer (warning: many pics) Richie Show off your project 41 09-01-2005 05:24 PM
Good time to buy carputer components? Linus General MP3Car Discussion 19 11-25-2004 08:57 PM
semi-newb, need help planning for carputer in a Mazda3 Stealth915 Newbie 9 10-23-2004 02:25 AM
Thinking of selling my old carputer for an ipod churnopol General Hardware Discussion 2 10-15-2003 10:10 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
