Old 05-09-2004, 03:38 PM   #1
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
Lilliput keeps resetting brightness levels ?
just wondering if anyone has the same problems.. it seems to zero brightness and contrast..
CdRsKuLL is offline   Reply With Quote
Old 05-09-2004, 05:05 PM   #2
htsea is on a distinguished road
My lili does that too, but it only occurs like 1/2 of the time. the internal ROM has some prob? Would powering the lili with car battery instead of cigar lighter solve the problem?
Car: 03 Maxima SE
Carputer Hardware: AMD Athlon XP1800+, Full size MB, 512MB RAM, 20G HDD, FX5900, SB Live
Screen: Lilliput 7" Touch
GPS: TN200 USB GPS Mouse
Install pics: http://members.shaw.ca/hermanao/carputer.html
htsea is offline   Reply With Quote
Old 05-09-2004, 09:40 PM   #3
masch
Same here, I get that problem often as well.
If you power the lilly through a car battery, how do you turn it off? (I mean, completely)
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 05-10-2004, 04:41 AM   #4
ozoffi is on a distinguished road
Look This -> http://www.mp3car.com/vbulletin/lcd-display/25672-display-brightness.html
Will be help me!
Regards
Oliver
http://picasso.zoffi.net
ozoffi is offline   Reply With Quote
Old 05-10-2004, 01:45 PM   #5
the_dude is on a distinguished road
I have a similar problem so I hooked it up to the 12 volts from the computer power supply. Are there any problems with that? It seems to be just as bright and functional as the ac wall plug.
- Kyle
the_dude is offline   Reply With Quote
Old 05-10-2004, 01:58 PM   #6
Bobby Digital is on a distinguished road
- Kyle
That's how I have mine and I don't think there is a problem with this method at all (as long as the power is still going through the egg shaped adapter thing). It's probably the best way to do it anyhow, since it's a clean 12V and it's only supplied when the computer is on (ie. screen is only powered when you need it).
Bobby Digital is offline   Reply With Quote
Old 05-10-2004, 04:24 PM   #7
I'm actually bypassing the egged shaped thing. I assume it's just designed to keep around 12 volts from a car battery. A regulator? I'm not positive but it seems that when I hook it up the screen is dimmer, like the egg isn't doing that good of a job. I figure the 12 volts from the computer has got to be pretty solid power supply. It's hard to A\B from my house to car for brightness but when I hooked up the dc egg unit to a 12 volt battery in my house and then the wall, the egg unit is definately dimmer. Maybe the batter is funky, I don't know(It reads 12.5 volts with no load).
Maybe I'll try the egg thing hooked with the computer power supply and without.
- Kyle
Old 05-10-2004, 05:02 PM   #8
FreeDrive Creator
CdRsKuLL's Avatar
this post wasnt really about the brightness of the lilliput, more the settings in the menu sometimes changing for no reason
Old 05-10-2004, 08:20 PM   #9
yeah, but like most topics they shift to something else, hence the other posts only somewhat related.
Old 05-11-2004, 05:50 AM   #10
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
See, now it's changed to be about posts going off topic!
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Lilliput 7" TS Brightness way too low!! Mircea LCD/Display 3 07-06-2004 08:36 PM
Lilliput Powering On/Off problem masch LCD/Display 0 05-09-2004 12:55 PM
Who have lilliput 7" ? >> brightness ??? DenisJ LCD/Display 4 04-20-2004 01:26 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
