Old 05-09-2004, 06:12 PM   #1
bambooracer is on a distinguished road
Need replacement connector for Lilliput
I have damaged the connector on the back of the LCD. Does anyone know where I can get a replacement. I just need the beige colored piece that pivots up and down to hold the ribbon cable in place.
Thanks!
bambooracer is offline   Reply With Quote
Old 05-09-2004, 07:14 PM   #2
The toothpick solution
What do you think of this solution?
I found that just gluing the broken piece didn't exert enough downward pressure on the cable. I tried 4 different glues: Loctite SuperGlue Gel being the best because it was thick and didn't run down into the connector and it sets within 30 seconds (because I couldn't find a good way to safely clamp it while the other glues set in 20-60 minutes).
However, in the end, a wooden toothpick worked perfectly and I didn't use any glue at all. The duck tape doesn't do anything, I just didn't want to remove it after finding something that works.
Old 05-13-2004, 01:17 PM   #3
Supra TT is on a distinguished road
Hi
I've just fouind myself in a similar position so I'll give your method a try.
I also need a replacement ribbon cable - it's the same one that's shown in your pic, the one that goes from the back of the panel to a circuit board.
Any ideas where I could get hold of one?
JB
Supra TT is offline   Reply With Quote
Old 05-31-2004, 01:47 AM   #4
mportobello's Avatar
mportobello is on a distinguished road
This solution isn't perfect. Anyone know where I can get a replacement connector (see pictures in first post).
When I put any pressure on the right side of the plastic case, the screen goes blank or appears scrambled.
Replacement cables are available for $3 from www.digitalww.com
1997 Toyota Celica
mportobello is offline   Reply With Quote
Old 05-31-2004, 10:37 PM   #5
Pokey's Avatar
Pokey is on a distinguished road
I have the exact same problem, does anyone know where to purchase broken latch?
Dual Lilliput's 70NP/C/T
Syntax SV266AD KT266A
AMD Athlon XP 2000
Viking 256MB DDR
D-Link Wireless 802.11B
Seagate 120GB
OrbitMicro 250W DC/DC converter
SII Wireless Audio Link
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
Pokey is offline   Reply With Quote
Old 06-01-2004, 06:04 AM   #6
dominiclu is on a distinguished road
I have the same problem, but I can find source here(Taiwan). I'm planning to replace the beige cover with new one only. Otherwise, it's also not so difficult to replace whole connector.
Anyway, I just order this parts today. Once it's done, I'll see what I can have help to you guys.
Dominic Lu
dominiclu is offline   Reply With Quote
Old 06-03-2004, 01:05 AM   #7
Thanks dominiclu! Let us know how it works.
I am going to try ordering a couple of different connectors from www.digikey.com and see if any of them fit.
Old 06-18-2004, 07:53 PM   #8
Digi-Key Part: HFR40CT-ND appears to be very similar. I've got it here and I will try in the Lilliput when I mount the screen in the car.
I've also orderd HFJ40CT-ND (close, may work) and WM5684CT-ND (definitely won't work).
Old 08-15-2004, 08:39 AM   #9
Pokey's Avatar
Has anyone found a replacement for the header and ribbon cable?
AMD Athlon XP 2000
Viking 256MB DDR
Seagate 120GB
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
Old 08-16-2004, 07:03 AM   #10
RS3RS's Avatar
RS3RS is on a distinguished road
Seems a lot of people have this problem. Any tips on avoiding breaking it? I'll be ordering a lilliput soon, and don't want to destroy it when I take it apart...
RS3RS is offline   Reply With Quote
Old 08-16-2004, 07:21 AM   #11
STIdev's Avatar
STIdev is on a distinguished road
digitalww will sell you a cable for something like $3. Its a Parlex 40 pin 0.5mm. I got some free samples from Parlex.
2004 Subaru STI
AMS CG65 2.4Ghz P4 w/512MB DDR, 40GB HD
Audigy2 ZS, Xenarc 700TSV, Gyration Media Center
WinXP Pro, ME 2.1, AudioBahn 5100T Amp
AWT10X Sub, JL XR100-CT tweeters
Sony XPlod fronts, Kenwood Excelon rears
STIdev is offline   Reply With Quote
Old 08-16-2004, 06:29 PM   #12
Pokey's Avatar
yea, he sold me two that were the wrong type, apparently there are two types, i think one style is on one side and the other is on one side and the other side on the other end. Its been almost 3 months since i bought my Lilliput from him with no more messages from him......HHmmff
When i separated my cases, the ribbon cable was only 3" long and that screwed my header up, and trying the toothpick fix, just screwed my cable, not that its a bad fix, but my cable was too short.
Sure wish i had a cable to fix this display, Armen?
AMD Athlon XP 2000
Viking 256MB DDR
Seagate 120GB
Digimoto OBD-II
Earthmate GPS
BU-303 USB GPS
D-Link Bluetooth
Old 02-21-2006, 05:09 PM   #13
cartdan is on a distinguished road
Bambooracer - did you ever get the HFJ40CT to work? I've got a semi-busted connector (only one side will latch) and will probably have to replace it once the car jiggles it lose...
I sent an email to digitalWW also, trying to see if they had any of the connectors.
Does anyone know if the lead pitch on the cables? I'm guessing 0.5mm...
- Dan
cartdan is offline   Reply With Quote
Old 02-27-2006, 01:57 AM   #14
Nope. I ended up stuffing the cable into the connector and using glue with a toothpick to hold the cable down. The duck tape didn't help.
Old 11-29-2006, 09:54 AM   #15
LordHowe is on a distinguished road
anyone found the correct part number?
LordHowe is offline   Reply With Quote
looking for replacement remote for 7" lilliput lesko LCD/Display 3 03-17-2007 06:47 PM
Replacement usb wire (earthmate) Cyber_Drone GPS 2 04-26-2004 01:38 PM
Compaq Armada M700 screen replacement? jol LCD/Display 7 10-15-2003 05:52 PM
5" replacement bulb? nyconx LCD/Display 1 04-11-2001 02:15 PM
[Sproggy PSU] T6 replacement Shaper General Hardware Discussion 6 03-21-2001 07:54 AM
