Old 05-10-2004, 02:28 AM   #1
Mage's Avatar
Mage is on a distinguished road
Help with PSONE LCD mod
hey,
I just got done installing a matrox millenium II for my psone lcd mod Works great better than the rage on intel i856 I was trying to use. I got everything working great but 2 things.
1. I get full hight but have to ajust to to be in the right area (too low)
2. I can't get full waith from the screen.
I'm using powerstrip v.2.51 if that helps. any idea of how to fix this?
Mage
Mage is offline   Reply With Quote
Old 05-14-2004, 03:17 PM   #2
Mage's Avatar
bump
Old 05-14-2004, 04:14 PM   #3
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Down load the latest version of powerstrip and try it out.
This is what I have on Matrix Mystics 200.
Winamp5 1-1/2 size
GPS: Delorme Street Atlass.
I am using PowerStrip 3.49 (I think)
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 05-14-2004, 04:59 PM   #4
Mage's Avatar
Thanks for the replay I'm now using 3.49 and I get the same resalt ( but now after upgrading for free to paid I can't do custom res!) is the Matrix Mystics 200 same as the millenium II? what's your settings can't seem to get the pix clock below 30 too but I did get it to veiw save the with!
thanks again
Mage
Old 05-14-2004, 05:24 PM   #5
MySQL Error
MatrixPC's Avatar
I am using freeware/trial version of PowerStrip. I am not sure if the Mystics 200 is the same as Millenium 2. But if you can do Custom resolution, it will work.
How did you mod the cable? 270 Ohm resistor trick or a TTL Sync circuit? Check some of the PSOne mod threads for the TTL Sync circuit I posted. That the one I used.
Old 05-14-2004, 05:48 PM   #6
Mage's Avatar
I'm runing stright sodared wire no sync circuits or resistors via one of the post I went over both mpro and starfox's? for the last 3 months! I'll look up the ttl sync circuit mabe that will help But I dont think it's a sync problem thanks for the help!
Mage
Old 05-15-2004, 12:05 AM   #7
Mage's Avatar
WooT! I got it to do full with now! but it does this roll thing it just rolles could it be becuse the vid card will not alow it to go below 30hz? or something else?
thanks for all the help!
Mage
PS: I'm not using power strip that's was what was messing it up!
Old 05-15-2004, 01:33 PM   #8
Hcomplyr's Avatar
Hcomplyr is on a distinguished road
looks like nobody has taken off the clear plastic on their screen either
so you just wired it staight through and it worked? nice! and how are you using the screen without power strip? i haven't had any luck here
Hcomplyr is offline   Reply With Quote
Old 05-15-2004, 05:55 PM   #9
Mage's Avatar
I made a driver for the psone screen. it didn't work on anyother card I had So mabe only the millenium II can do it? dont know untell I get it from scrolling wich I belive is a refresh rate problem? or pixel clock problem.
Mage
Old 05-15-2004, 08:32 PM   #10
xtra is on a distinguished road
mage
i already have a compatible video card(TNT) and the official sony lcd.
i only need some cabling to get this mod working , correct?
a standard VGA cable and some sodering?
xtra is offline   Reply With Quote
Old 05-15-2004, 11:48 PM   #11
Mage's Avatar
that's what I did serach for psone and read all the therads there's a lot of good info just not for the Millenium II :\
mage
Old 05-31-2004, 11:31 PM   #12
Vicious is on a distinguished road
Scrolling Problem
Mage
I think the scrolling problem happens only if Csync is not enabled. It might not be available for your card too. I used to have it with my Geforce 2 until I got a Matrox Millenium G200.
Vicious is offline   Reply With Quote
Old 06-02-2004, 10:20 PM   #13
Hcomplyr's Avatar
good thing i just got a matrox from work (they throw out the niftiest things)
Old 06-03-2004, 02:44 AM   #14
starfox's Avatar
starfox
You'll see scrolling if your horizontal and vertical refresh are set incorrectly.
What resolution are you running the display at? I don't know what the NTSC display looks like as i only did the mod on a PAL Sony PSOne display..
starfox is offline   Reply With Quote
Old 06-05-2004, 03:09 PM   #15
Mage's Avatar
I'm running in both 640 by 480 or 800 by 600 Csync is enabled.
thanks for the help and sorry for the long wait to reply I was out of town.
Mage
PS1 LCD VGA mod Summary... odin836 LCD/Display 26 01-13-2007 07:16 AM
Original PSOne LCD and Circuit Board SuAsDu LCD/Display 0 01-18-2004 12:46 AM
Sony PSone LCD VGA mod wiring ProjectTwin LCD/Display 14 12-23-2003 09:11 PM
PS One LCD mod help greenglo LCD/Display 3 09-03-2003 04:41 AM
Anyone figured how to make the Radion detect the modded Psone LCD yet? M pro LCD/Display 12 07-14-2003 05:12 AM
