Old 05-13-2004, 11:49 AM   #1
delussional77 is on a distinguished road
unable to get touchscreen on lilliput
I have the 7" lilliput touchscreen and after loading the drivers and software am having a hard time configuring it to actually use touchscreen. Do i have to use the stylus that came with it? How do you configure this properly so it doesn't rely on the mouse. Thanks.
also, the CD the drivers came on was a mini-disc and i re-burned it to a full disk so that there would be no complications when using my slotload dvd-rom, do you think this could have caused a problem? Should i reinstall the drivers and utilities?
delussional77 is offline   Reply With Quote
Old 05-13-2004, 11:54 AM   #2
samc's Avatar
samc
burning the cd is fine. and I always use a stylus to calibrate. Usually its very accurate.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 05-13-2004, 02:34 PM   #3
i just don't get any touchscreen response period....like i haven't installed it. I am not sure exactly how to configure the settings ....any advice?
Old 05-13-2004, 02:56 PM   #4
samc's Avatar
samc
you mean once you install the TS program and plug in the usb cable you dont see the touchscreen recognized?
Old 05-13-2004, 03:05 PM   #5
Clover
Grayscale's Avatar
Grayscale is on a distinguished road
dont use the drivers that came with the cd, there are some from http://www.egalax.com.tw/Download.htm that work well i believe
Grayscale is offline   Reply With Quote
Old 05-15-2004, 08:07 AM   #6
spaced_chris's Avatar
spaced_chris is on a distinguished road
I find that when I try to install the drivers for the lilliput onto a laptop I have that I can't get back into windows after the installation (Windows XP Home).
Any ideas of what might be wrong?
spaced_chris is offline   Reply With Quote
Old 05-15-2004, 09:09 AM   #7
Magpie is on a distinguished road
I had the same issue when I first got my screen. I found that I was clashing with another device on my system. For me it was my Bluetooth USB device. I had to unplug the device AND remove the drivers before the install of the touch screen was successfull. After that I was able to re-install the Bluetooth device.
My advise would be to remove as many external devices as you can and then try to install the screen. My guess is it was trying to install and use a restricted port range which was already in use. The bluetooth device appeared to be a little more forgiving on install.
Magpie is offline   Reply With Quote
Old 05-16-2004, 06:32 PM   #8
n00b 4 life
mp3oplecarrier's Avatar
mp3oplecarrier is on a distinguished road
I think I may have the same problem, no touchscreen at all even though xp appears to have installed it correctly.
I have just been inside the thing to see if there was anything loose with no joy, have any of the other posters with this problem got anywhere?
....Yes, I know it has a stupid name, those crazy Japanese!
mp3oplecarrier is offline   Reply With Quote
Old 05-22-2004, 02:25 PM   #9
hopefully i do not need to open mine up
the only thing i can think is that when setting up the drivers i do recall noticing that the installation for the USB failed (or needed to first be connected to the net...possibly to register my XP copy which i haven't done yet). If the USB hasn't been set up yet (or correctly) then that could be my problem right?
Old 05-22-2004, 02:26 PM   #10
these drivers are for 9x/ME though...still gonna work on mine?
Old 05-22-2004, 03:39 PM   #11
jusatry's Avatar
jusatry is on a distinguished road
how do you have it hooked up?
the USB physically i mean.
jusatry is offline   Reply With Quote
Old 05-22-2004, 04:49 PM   #12
false alarm, got it all to work...just had to have a computer guru help me out at my house :-)!
Old 05-22-2004, 05:32 PM   #13
n00b 4 life
What was it in the end?
Old 05-22-2004, 06:37 PM   #14
reinstalled the drivers for USB and then i noticed in the Device Manager that the TouchScreen was "X"ed out so i just enabled it and it worked. Problem is the calibration isn't right. If i try to get to the taskbar it will stop just short of it. How do i fix this? Or how do i calibrate?
Old 05-22-2004, 11:43 PM   #15
btown's Avatar
btown is on a distinguished road
yeah i need to know how to calibrate mine, i installed the software and the touch screen works but not for a half inch around all the edges
btown is offline   Reply With Quote
No Signal on Lilliput 7 Inch touchscreen. SuperDave01 LCD/Display 7 05-04-2008 10:36 AM
Lilliput touchscreen problem samc Input Devices 1 05-09-2004 12:12 PM
*****ing lilliput touchscreen mrzigzag LCD/Display 21 04-13-2004 03:31 PM
WTB Lilliput with broken touchscreen or Lilliput without touchscreen dettman23 Classified Archive 1 04-11-2004 09:12 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
