Old 05-20-2004, 08:47 AM   #1
Goose's Avatar
2002 Toyota Yaris and 7" LCD need help
Hello.
My eks girflriend has 2000 Toyota Yaris 1.3l.
She want carputer in this car.
So I am asking you guys where can I mount LCD in this car?
Maby somone has some ideas? Meby someone can play a little with Photoshop?
I attach a picture of a center console.
BTW. The LCD can't be mounted under the console therefor the pictures doesæn not show the buttom part....
Goose is offline   Reply With Quote
Old 05-20-2004, 09:29 AM   #2
Raw Wave
god_of_cpu's Avatar
Get a girlfriend with an easier car to modify.
Seriously though, maybe a fold out LCD where that thing between the vents is now or replace the radio.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 05-20-2004, 10:01 AM   #3
I agree! That will be a pain to modify to fit the screen!
VIA Epia II
256MB 266DDR Ram
90GB Wester Digital
Bluetooth/Deluo GPS
Lilliput 7" Touchscreen
Mazda 6 Carputter > Click Me!
[iG] is offline   Reply With Quote
Old 05-20-2004, 10:01 AM   #4
MySQL Error
Scouse Monkey's Avatar
[quote=god_of_cpu]Get a girlfriend with an easier car to modify.
QUOTE]
Ha Ha
That silly floating speedo thing is in the way - what is wrong with normal dials? And I thought my dash was a pain!
What is the usable width between the vents? Easiest option might be a custom tilted piece to put it covering the CD player and CD trays (if that's hat they are) with the LCD pointing up but this might be too low (even mor dangerous with a girl driving ) and the gears stick might hit it.
Could move the buttons from above the dials to below and put a nice sculptured screen housing betwen the vents which could be slightly angled to the driver and match the speedo housing a bit. Even if the width is slightly too small you could sculpt small cutouts into the sides of this housing - could look sweet.
Andy
Scouse Monkey is offline   Reply With Quote
Old 05-20-2004, 10:08 AM   #5
looks like the radio cant be replaced ( cd player is part of the dash ) what is that under the cd insert slot and buttons ( looks to me like the old porsche cd storage pop-out trays) if that is the same size as a din opening then put a fold out monitor
if not then maby yank all the guts out of the cd part and cut a din opening you may have to put plastic back in then cut a din opening and at the top maby put a small 3-5 line lcd display to show track info and what not when you leave the lcd closed
what does a yaris look like are you in the uk or in the states got a pick of the whole car
hth
chad
tracker92 is offline   Reply With Quote
Old 05-20-2004, 10:11 AM   #6
Does this car have an overhead console? Alot of people are stuck on the idea of putting the screen in the dash when a lot of cars could simple have them fold down out of the overhead.
The Durango Kid is offline   Reply With Quote
Old 05-20-2004, 10:27 AM   #7
Goose's Avatar
The car has a lot of space to mount LCD up from the roof.. hm... I will think about that..
The radio between vents is a Orginal Toyota radio with driveing computer..
So I may take it out and mount LCD there...
The idea I have is:
Take out the radio between vents and put LCD there.
Take out a cd-box under Orginal cd player and but a regular Car cd player with aux-in..
I think it will be a best solution...
Old 05-20-2004, 10:29 AM   #8
SAScooby's Avatar
ditch the factory speedo and run an obd11 device to show speed and put the screen in that little boob shaped bump up on top in the middle, go on you know yo uwant to, or what about straight in front of the driver where the speedo etc normally sits, may be tricky to touch the monitor but hey get a powermate and remote control installed instead
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 05-20-2004, 10:34 AM   #9
Goose's Avatar
hm... I will talk to her about this today..
Infron of driver I can't... It is becouse the Police doesn't like LCD's in the car and If they find a custom LCD whitch points in the drivers direction then thay gived you a ticked...
Old 05-20-2004, 08:32 PM   #10
shidarin's Avatar
What in god's name is Yaris?!
shidarin is offline   Reply With Quote
Old 05-20-2004, 08:39 PM   #11
Yaris is the JAPAN spec name for the Toyota ECHO (in the USA thats what its called)
Echo is much better then yaris .. as it has a 1.5l VVTi (much more power) and also has airbags (standard) yaris its option . also echo has a much better and rigged front ( impact protection) .. bigger wider wheels(14 inch .. instrad of 13)
i know this because here where i am at ... localy bought (lowend) toyota;s are yaris .. (at dealership i mean) .. those that go to usa to buy it (cheaper) ... those are toyota echo's ....
Q_gamelogic is offline   Reply With Quote
Old 05-20-2004, 09:20 PM   #12
dodgetimes2's Avatar
Why would you want to do all the work of a carputer for an EX girlfriend? Hoping to get back in her pants??
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 04-08-2007, 02:11 AM   #13
Omoikane's Avatar
yaris, echo, same thing
Omoikane is offline   Reply With Quote
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
Will 7" In-Dash LCD fit in DOUBLE-DIN? integsrtite LCD/Display 5 05-12-2004 12:43 AM
Need help selecting a 7" TFT LCD for <$200? prospero LCD/Display 22 04-06-2004 10:33 AM
Perfect 7" widescreen LCD? Giuliano LCD/Display 30 02-28-2004 09:41 AM
8.4" Touchscreen LCD, 7" Wide LCD & portable DVD player with TV Tuner nolmscheid Classified Archive 4 03-16-2002 02:32 AM
