Old 05-20-2004, 10:05 AM   #1
issues with lilliput
Armen or anyone else here,
I'm having a wierd thing going on with my lilli 7" touch. I've found that if i power on the machine with the screen off and wait until xp fully boots then turn on the screen, the touchscreen works for a while...like 5 minutes. then it just stops functioning. if i turn on the screen immediately when i turn on the machine, it may or may not work by the time xp boots.
even when the touchscreen is not working, xp and the touchkit.exe still detect the resistive touchscreen. it's just that if i press the screen, nothing happens. i'm thinking it may be related to a capacitor or heat or something. that time thing sort of eludes to that. any ideas would help.
krystar is offline   Reply With Quote
Old 05-20-2004, 02:28 PM   #2
If it detects the touchscreen resistive driver, the fault would lie after the touchscreen controller. It could be the wiring from your controller to the touchscreen or it could be the touchscreen itself. Seems like the +V on your touchscreen is loose
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 05-20-2004, 03:52 PM   #3
masch, so we're talking pull it apart and check the 4 wires on the touchscreen for resistance right ?
Old 05-20-2004, 05:32 PM   #4
digitalww's Avatar
Since you're not to far away from me you can ship me your usb controler and the touch panel. I will check them both and will find the problem.
Let me know.
Armen
http://www.digitalww.com
digitalww is offline   Reply With Quote
Old 05-20-2004, 05:45 PM   #5
pip
pip's Avatar
Armen, my touchscreen seems not to be working too (I just bought the d**n thing from carpod.ca too). The USB controller is recognized, I can caibrate but it always registers the position at the bottom left of the screen. I have tried opening the thing up & making sure there was no pressure on the touchscreen but to no avail.
How much would you charge to fix?
pip is offline   Reply With Quote
Old 05-20-2004, 05:58 PM   #6
armen, i'm electronically competent. maybe give u a call and go some some basic checks before sending it to u and wasting both our times and frustrations?
Old 05-22-2004, 12:01 AM   #7
armen, i just took it apart and took out the panel. from what i read, i should detect a chance in resistance on the wires if i touch it or something, right ? well i don't hehe. should i still send this to u and have u check it out? I PM'ed u my phone #. let me know. thanks armen
armen r0000leeezz
Lilliput install in and Impreza, Lilliput issues SubPuter LCD/Display 76 04-19-2004 09:56 PM
Still having issues with Lilliput and Winamp Viz's d1g1tal3nvy LCD/Display 3 04-19-2004 09:48 PM
Lilliput quality issues fearthepenguin LCD/Display 11 03-05-2004 12:52 PM
Lilliput flickering issues SubPuter LCD/Display 5 01-28-2004 10:53 AM
Lilliput 7" VGA and EPIA M9000 issues... heat LCD/Display 9 01-15-2004 04:57 PM
