Old 05-21-2004, 10:50 PM   #1
Lilliput Screen - Serial db9 connector
Hi... thanks for the reply on the Lilliput screen question. I have two quick follow-ups:
1. Where exactly can I get one of these connectors...
2. and how to I actually connect it to the screen and the pc? Do I need to order the cable, cut it and splice wires? If so, which cable to I splice/fuse together... short cable coming from monitor... or longer cable that has a vga connector on the other end?
Any help is greatly appriciated. Thanks again.
Original Post:
http://www.mp3car.com/vbulletin/lcd-display/26725-lilliput-blue-screen-issues.html
Original Post Title:
Lilliput "Blue Screen" Issues
Original Message:
Hi all... I am having serious issues with my lilliput: The screen is constantly blue... I can see everything on the screen, you can tell there should be more colors, but it has this overall blue tint to it. I have tried the autogain feature but that too does not work. Is there something loose inside or is the screen damaged? Any help and suggestion would be great. Thanks folks.
LekanB is offline   Reply With Quote
Old 05-21-2004, 11:23 PM   #2
eCar™'s Avatar
Your Lilli is sad. Try talking nice to it.
eCar™ is offline   Reply With Quote
Old 05-21-2004, 11:34 PM   #3
wkolodny's Avatar
The 9 pin connector is pretty crappy. Replace it with a serial db9 connector.
Don't Fear The Gurkey
Click here to check out My Setup
wkolodny is offline   Reply With Quote
Old 05-22-2004, 03:42 PM   #4
spyhunter's Avatar
mine has developed a similar problem, off colors and a blurry picture, its the connector
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
spyhunter is offline   Reply With Quote
Old 05-23-2004, 04:31 AM   #5
Talking
smartass
hnzly23 is offline   Reply With Quote
Old 05-25-2004, 04:09 AM   #6
Hi... thanks for all the replies on the Lilliput screen question. I have two quick follow-ups:
Any help is greatly appriciated. Thanks again all.
Original Post:
http://www.mp3car.com/vbulletin/showthread.php?t=26725
Old 05-25-2004, 08:31 AM   #7
wkolodny's Avatar
Original Post:
I replaced mine witha serial DB9 extension cable I picked up at RadioShack.
http://www.radioshack.com/product.as...%5Fid=950-0225
I just cut the DB9 cable in half and connected one half to the monitor and the other to the vga/usb cable. Works much better now.
For the liliiput 9 pin connector:
Cut both sides of the connector off and plug them together. Then strip the wire ends off of both sides and use a meter to verify connectivity between the wires. The brown/purple leads and the blue/orange wires are crossed on my lilliput. All the rest were the same color.
Wire one side of the DB9 to the monitor wire and the other side to the VGA/USB wire. Check to make sure connectivity is the same between the wires for the new connector as the old connector.
http://www.mp3car.com/vbulletin/show...8&postcount=13
Old 05-26-2004, 12:14 AM   #8
Thanks wkolodny!
Hey man... thanks for all the help. I really appriciate the help.
Lilliput install in and Impreza, Lilliput issues SubPuter LCD/Display 76 04-19-2004 09:56 PM
Still having issues with Lilliput and Winamp Viz's d1g1tal3nvy LCD/Display 3 04-19-2004 09:48 PM
Resolution Issues with new Lilliput eTard LCD/Display 5 04-04-2004 04:19 AM
Lilliput quality issues fearthepenguin LCD/Display 11 03-05-2004 12:52 PM
Lilliput 7" VGA and EPIA M9000 issues... heat LCD/Display 9 01-15-2004 04:57 PM
