Old 05-22-2004, 12:29 AM   #1
HELP I got lilliput problems
Recently my lilliput started having problems. Basically The images were not showing properly. It was kinda dark and off color. After doing research on these forums I realised that the ground wire on the lilliput monitors were noted for coming loose. I therfore opened the monitor a week later and lo and behold the groud wire was loose however there was also a brown thingy shaped like a capacitor that was lying in the back of the casing and not attached to the board. I figured I now had a real problem. After soldering my ground wire back I looked all over the board to see where this little capacitor thing came from but didn't find it. Now my composite video inputs work real fine and I get "no signal" and the jurassaic park logo whever I go into VGA mode. Anybody has a detailed picture of their lilliput board so I can see where this thing goes and if anyone ever cut their pin off the monitor and soldered the VGA cables directly I would like to know which wire goes where.
Before you guys ask I already did some research on the forum for the pinouts and I found a site with a wealth of information however My wires seem to be slightly different from what they have there. - Oh my touchscreen still works too. I just need the vga to work.
Help me please.
Will post a pic tommorrow
EDIT
This is the little capacitor like thing that I found in the housing.
http://images.cardomain.com/member_i...308228_150.jpg
95 Toyota 4Runner
Elliott's MP3 Runner
Components of my setup takes up way more than 250 characters and no matter how I tried to make it fit here it just wouldn't so please check my page.
Dluvr22 is offline   Reply With Quote
How I fixed my lilliput touchscreen problems gubon13 Input Devices 9 05-22-2004 07:21 AM
More Lilliput Problems - Tried Searching project94coupe LCD/Display 12 05-19-2004 09:37 AM
Lilliput problems (yet some more) samc LCD/Display 7 05-06-2004 10:51 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
touchsreen problems on lilliput mrzigzag LCD/Display 1 12-03-2003 03:57 PM
