Old 05-22-2004, 07:36 PM   #1
Xenarc 700TSV or 700TS?
Ok, i've decided to go with a xenarc screen to avoid all the problems that people seem to be having with lilliputs. But i'm not too sure what xenarc monitor i'll need. TSV is with video input and TS is without right? I'm planning on having a reverse cam, so could i just plug it right into the monitor and press a button on the monitor to switch to the camera view? Is it possible to just go with the 700TS? Thanks for any help
--Nick
fraganic is offline   Reply With Quote
Old 05-22-2004, 08:39 PM   #2
If you plan on having a reverse camera I would recommend the TSV. It has a "AV2 first" mode. In that mode the screen will switch to AV2 automatically if signal is detected and then back to the input that was selected before when the signal is gone. What I did was to power the camera using the reverse light line. This way as soon as I put the car in reverse the screen switches automatically to the camera and when I put the car in any other gear the screen goes back to VGA.
Izik is offline   Reply With Quote
Old 05-22-2004, 08:54 PM   #3
fluffy2097's Avatar
Get the VGA input. You cannot loose with VGA.
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
fluffy2097 is offline   Reply With Quote
Old 05-22-2004, 09:03 PM   #4
Thanks, and i like your sig fluffy..
Old 05-22-2004, 09:29 PM   #5
Thats a good idea, what kind of camera did you use?
thepogcbr900rr is offline   Reply With Quote
Old 05-22-2004, 09:46 PM   #6
http://www.digitalww.com/camCA.htm
Old 05-22-2004, 09:47 PM   #7
Both the TS and the TSV have VGA. The TSV has VGA as well as two AV inputs.
Old 05-22-2004, 09:48 PM   #8
Thats powered by a 9V, how did you splice it in to your reverse?
Same amount of power?
Also do you just run the rcas to the back of the TSV from the camera?
Old 05-22-2004, 10:10 PM   #9
Actually if you look at the link it's 12V.
Nice clean idea Izik.
-Daniele
dgaetano is offline   Reply With Quote
Old 05-22-2004, 10:12 PM   #10
How come the pic below from the site, looks like a 9v?
Old 05-22-2004, 10:44 PM   #11
The camera power should be (per the manual) between 8v-12v. If you are worried about using the car's 12v you can use a relay (connected to the reverse light) and run 12v from the computer power supply.
I run the one RCA cable to the screens AV2. I don't use the microphone.
Expired - Xenarc 700TSV Group Buy KarPC.com Classified Archive 82 05-20-2004 02:03 AM
Xenarc 700TS 7"VGA LCD (NIB) MUST SELL!!! bulldog_sds Classified Archive 6 04-12-2004 05:05 PM
Xenarc 700TS & 700TSV anti-glare? Shark LCD/Display 1 02-15-2004 11:57 PM
WTB: Xenarc 700TSV casing paulpv Classified Archive 0 10-18-2003 01:44 AM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 07:38 AM
