Quote: Originally Posted by briang
after the LCD screen is pulled out and in the vert. position, how much of a gap is there between the dash and the back of the LCD? Can it be pushed back flush against the dash when open?
The gap is fairly large, about 6 cm (2.5 "). You can push it back a bit by releasing two latches behind the LCD but it ain't easy and it's not designed for that. I'm not too crazy about the gap, it makes the mechanics a bit fragile.
The positive side of a large gap is that you can swivel the screen about 20 degrees either side.
