Old 06-07-2004, 09:10 AM   #1
Lilliput causing engin noise
Hi all,
i finally installed me system over the w/e and have a little problem i need help on.
I've hard wired the cigret lighter to the back of the car connector, (snipped the connector and wired it directly to the back of my car lighter connection) i noticed that soon as i start the engine i get the engine noise, if i pull the power connection from the screen my noise geos away.
Any idea's on how i can reslove this.
P.S, i dont really want to open the screen, i'm happy to use the supplied car power connection (the one with egg on it)
eazyrog is offline   Reply With Quote
Old 06-07-2004, 09:13 AM   #2
How do you have your carpc connected?
I assume the engine noise is coming from the speakers thru the audio out of your car pc?
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 06-07-2004, 09:19 AM   #3
Hi mate,
Its a laptop running on batteries ( not even used the inverter yet) the line out geos to a SoundLinx adaptor which replaces the trunk cd changer, (single jack to rca's) i have proved it comes from the screen, soon as i remove the power connector from the screen the noise goes away.
I have simply connected the egg cable to the back of the cig connector
Old 06-07-2004, 09:23 AM   #4
what if you keep the pwoer connector from the screen connected,
and remove the monitor jack from your notebook?
Old 06-07-2004, 09:24 AM   #5
Sorry mate, dont understand, if was to remove the connection from my laptop to the car i would loose all sound ?
Old 06-07-2004, 09:40 AM   #6
No, I mean.. remove the monitor plug on your lilliput from your monitor jack on your notebook. Basically, just disconnect the lilliput from your notebook.
Keep your audio cable into the audio jack of your notebook.
If you still dont understand, I assume there are 2 wires connected to your notebook
1) The audio cable to your car speakers <- keep this connected
2) The monitor cable <- try disconnecting this to remove the noise
Keep the lilliput powered thru the cig connector.
Old 06-07-2004, 09:45 AM   #7
Oooo, me being thinck mate.
I' try it this evening, however i have proved that eveytime i remove the Power connector from the scren the noise goes away.
Old 06-07-2004, 09:47 AM   #8
If I read your config correctly, keeping everything connected and then you remove the monitor plug - it would also make the noise go away.
Old 06-07-2004, 09:48 AM   #9
No, i remove the Power Connection from the Lilliput screen. i have not tested removing the Monitor Plug yet.
Old 06-07-2004, 09:54 AM   #10
Yes, that's why I said "also". I am aware that you have not tested it yet.
Do that first, and then I'll explain to you why. (provided removing the monitor plug solves your problems - there could be other variables too not yet mentioned in this thread)
Old 06-07-2004, 09:58 AM   #11
thanks mate, will try it tonight and get back to you
Group buy for the cheap MagicPower 120W MPD-810H DC-DC PSU Telek Power Supplies 86 04-04-2005 04:57 PM
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
need some noise help spyhunter General MP3Car Discussion 6 07-20-2003 11:20 PM
Power noise - the horror!!! mtmsol Power Supplies 3 06-19-2001 10:13 PM
