Old 06-09-2004, 11:26 AM   #1
wylie-c's Avatar
wylie-c is on a distinguished road
Things to do with an extra LCD ( slightly OT, but oh well )
So you have an extra LCD you're not using? Why not make your own home theatre projector!
The ingredients:
3M OHP Model 1730
Mobile Authority M71 7" widescreen TFT
- Non-VGA, 1440 (480) x 234 resolution
- composite input only
Blackout cloth screen ( with lots of wrinkles! )
100" projected image from a distance of 14 feet
The pics: ( some are quite large )
Testing the setup for the first time
King of the hill at 40" while testing
At 100" on the blackout cloth
King of the hill at 100"
Another at 100"
The stripped LCD
The OHP
One last pic, the wrinkly screen, but it shows the size of things and relative distance of OHP to screen
wylie-c is offline   Reply With Quote
Old 06-09-2004, 11:53 AM   #2
Superduck's Avatar
Superduck is on a distinguished road
That's very cool.
I've got a stupid question. Will that work with pretty much any LCD screen? And I guess any old OHP?
My coworker is looking to do the same thing.
Kris
Superduck is offline   Reply With Quote
Old 06-09-2004, 11:57 AM   #3
Ormo is on a distinguished road
I take it the OHP is providing the light for the projection rather than the backlight?
very very cool!
Ormo is offline   Reply With Quote
Old 06-09-2004, 01:14 PM   #4
binary.h4x's Avatar
binary.h4x
very very cool!
looks like both
binary.h4x is offline   Reply With Quote
Old 06-10-2004, 02:36 AM   #5
wylie-c's Avatar
The backlight is completely disconnected, you can see it still attached to the board with the connector unplugged. The panel must be completely seperated from the board, except for the ribbon cable, in order for light to pass through it. Pretty much any old OHP will do the job, and with a vga or svga or higher lcd you can get a very crisp picture that rivals commercial projectors. Just not as bright. Unless you retrofit the OHP with a 400w metal halide, then it's very close.
Old 06-10-2004, 03:01 AM   #6
Pokey's Avatar
Pokey is on a distinguished road
I have read an article about this, what is the distance of the OHP @ 100 dia" ?
Its cool, im thinking of doing the same thing, i have heard of doing it with a laptop LCD, what is the dia of the screen you are using?
Pokey is offline   Reply With Quote
Old 06-10-2004, 11:01 AM   #7
thelaw is on a distinguished road
Its a good idea, for more details there is www.diyaudio.com projection section. There is commercial LCD's produced for this purpose. You shouldnt use a normal LCD that you love an cherish unless you provide adequate cooling. LCD's will fade at high temperature, and too much heat will turn them a deep black (although they usually recover). Either raise the LCD slightly and blow air underneath, or use a metal halide ohp (you still might need cooling even then). Halogen 400W OHP will make this job very tricky, as they give off unbelievable heat waste.
Use a massive fan like wylie's
thelaw is offline   Reply With Quote
Old 06-10-2004, 11:37 AM   #8
cadence117's Avatar
cadence117 is on a distinguished road
check out http://www.lumenlab.com/forums/index.php?act=idx
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
cadence117 is offline   Reply With Quote
Old 06-10-2004, 11:47 AM   #9
brrman's Avatar
brrman is on a distinguished road
if its touchscreen, put it in your house and control your lights, AC, entertainment with it.
heh heh
Car: 2000 Audi A4 Avant 1.8t
Carputer 2.0: removed. Back to stock.
brrman is offline   Reply With Quote
Old 06-10-2004, 01:08 PM   #10
wylie-c's Avatar
Yes, there is a ton of good information at diyaudio. I have been reading the posts over there for quite some time. The pics were during testing, I do have it elevated off of the glass with a fan cooling the backside of the panel since then. If you have time to browse the diyaudio forum, it's well worth it. There are some peoples projects there that are simply amazing! To answer the question about distance, with a 7" lcd on my ohp, I have it 14' from the screen to produce 100 inches of movie watching goodness.
10.4" LCD monitor w/ TV tuner $260 Shipped NEW CDesigns Classified Archive 1 12-06-2003 07:14 PM
6.4"-8.4" VGA TFT LCD w/ Touch Screen Lag117 LCD/Display 5 12-15-2002 11:47 PM
Questions about CAr Mp3 and an Fm and lcd options cirixkid General Hardware Discussion 1 07-08-2002 01:56 AM
Small but functional Char LCD TheFly LCD/Display 5 04-23-2002 04:26 PM
F.S Some random extra things, CHEAP! HURRY! KaBoom Classified Archive 2 03-21-2002 07:58 AM
