Old 06-09-2004, 03:01 PM   #1
Chairboy's Avatar
Chairboy is on a distinguished road
Sunlight readable LCDs
Of interest, I was searching for LCDs that could be seen in direct sunlight and found these:
http://www.vartechsystems.com/produc...e-Monitors.asp
They might be of use for CarPCs, I know that I'm getting my car tinted to reduce the sun glare, but that might not be enough.
Anyone familiar with these guys?
Chairboy is offline   Reply With Quote
Old 06-09-2004, 05:24 PM   #2
eCar™'s Avatar
eCar™
http://www.mp3car.com/vbulletin/show...hlight=vartech
eCar™ is offline   Reply With Quote
Old 06-09-2004, 09:47 PM   #3
Chairboy's Avatar
heh, touche. Guess they're a little more expensive then Lillilputs then.
Old 06-10-2004, 02:10 AM   #4
Raw Wave
Confused's Avatar
Confused is on a distinguished road
Take a look and see if you can afford the new Xenarc 700TS(V) displays. I have one, and they're a lot brighter/clearer than the Lilliput and the older Xenarc, and it's pretty damn readable, even in direct sunlight
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 06-10-2004, 03:07 AM   #5
Pokey's Avatar
Pokey is on a distinguished road
1400 nits? Sounds like a projector!
That should do it...
Pokey is offline   Reply With Quote
Old 06-10-2004, 11:21 AM   #6
jamieo is on a distinguished road
Garry
How do you tell if you have a new one? I was told I would be supplied with the new version but it doesn't seem that bright.
Jamie
jamieo is offline   Reply With Quote
Old 06-10-2004, 11:53 AM   #7
Raw Wave
Confused's Avatar
Jamie
Well for one i've seen both the old/newer ones.
I'm pretty sure all the newer/brighter ones have the "heavy-duty" 20 pin connector with the two little buttons on either side, and the older one will have the crappy, flimsy 15 pin connector which will come out if you so much as dare to look at it.
Also the fact that mine is readable when the sun is on it is a pretty good clue too.
Garry
www.aimee.cc
Old 06-10-2004, 03:05 PM   #8
You seem to have me confused (pun intended) with somebody who doubts you have the newer model
I just want to know if mine is the newer model...
Mine has a connector with two latches either side. I wouldn't call it "heavy-duty" and I'm unsure of the number of pins (it's in my dash right now) but it hasn't fell out so I guess I've got the new version. Is there any other way to tell?
What kind colour scheme are you using? I'm currently using the brushed_metal theme (which I love) with mediacar (while working on my own software) but feel the colours do not lend themself to good visibility (read contrast).
Thanks,
Jamie
Old 06-10-2004, 03:18 PM   #9
Raw Wave
Confused's Avatar
jamieo,
I mean that I know the differences between the new/old ones as I have seen/owned both, so me outlining the differences means you can hopefully know
The newer connector might not be "heavy duty" to you, but it's certainly better than the old one!
I'm also using the Brushed Metal skin with MediaCar, but I did have to play with the brightness/contrast a little from the default (which were both set to 0) to get a better picture
Garry
www.aimee.cc
Old 06-10-2004, 03:24 PM   #10
How visible have you found your screen during the recent british sunshine?
Any chance of posting your settings since I'm having difficulty seeing mine clearly...
Thanks,
Jamie
Old 06-11-2004, 09:27 PM   #11
Exposure is on a distinguished road
I have what I believe to be the newer Xenarc 700 TS (V) due to the good connector and I must say it is very, very visible in direct sunlight. That is not to say a hood or something wouldn't help but it is very legible.
Exposure is offline   Reply With Quote
Old 06-12-2004, 05:13 AM   #12
Don't get me wrong - I can see my screen quite clearly in regular direct sunlight. However, most days since I installed it a couple of weeks ago have been very bright and that's when I can't see it very well...
I'll try setting the contrast etc up again.
Jamie
High Bright Sun Light Readable LCDs PORTUGAL LCD/Display 18 06-23-2004 12:19 PM
Need 7" sunlight readable, Apollo or other... Olli.D LCD/Display 2 10-16-2003 05:00 PM
composite input LCDs - are GPS programs really readable? aoLhaTer GPS 11 07-08-2003 03:19 PM
2 12.2" LCDs for sale Mr. Pute Classified Archive 0 09-15-2002 08:31 PM
Digital vs Analog TFT LCDs Telek LCD/Display 6 11-12-2001 02:08 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
