Old 06-10-2004, 12:04 AM   #1
Oracle is on a distinguished road
Xbox 7.2 Inch LCD to VGA (like PS1 Mod)??
Was in toys-r-us today looking for a ps1 display for cheap...$129....I passed.
While there though...I saw 5.6 and 7.2 lcd's from Intec.
http://www.inteclink.com/inteclink/p...reens.asp#8271
There is a multi-AV out....and it says tft...anyone think these guys can be made to work?? Like the PS1 lcd vga mod.
Oracle is offline   Reply With Quote
Old 06-19-2004, 11:42 PM   #2
Mehnock is on a distinguished road
Xbox 7.2 LCD
I bought one, took it apart and will attempt the VGA mod.
I'll take some pictures of the unit and the circuitry. It looks like the AVinput is connected to the composite input so no luck there....
I noticed that the screen has a controller board that receives 6 wires as input: power, ground, and other 4 (Could these 4 be R,G,B and sync?).
Mehnock is offline   Reply With Quote
Old 06-19-2004, 11:46 PM   #3
Hcomplyr's Avatar
Hcomplyr is on a distinguished road
it could be power or audio too, pics would help
Hcomplyr is offline   Reply With Quote
Old 06-20-2004, 10:33 AM   #4
Intec Xbox screen
OK I got some pics...
Here is what I know so far:
  • The Screen has S-video, composite and AV (24 pin) inputs
  • The AV (24 pin) and S-video seem to be connected together in the input pcb
All of this is connected to this pcb
Old 06-20-2004, 10:38 AM   #5
Intec Xbox display 7.2 inch
It looks like the screen works like the following:
S-video or composite are the main inputs
The signal is taken to a board that separates them into RGB and sync
Old 06-20-2004, 10:45 AM   #6
Intec Xbox 7.2 inch LCD
Then the new video signal is sent to the LCD controller through a 6 pin cable
Old 06-20-2004, 10:52 AM   #7
Intec Xbox LCD 7.2
Here are some more pics:
Old 06-20-2004, 07:21 PM   #8
Hcomplyr's Avatar
what do all of those pots do? you might be able to send the RGB signal to the second PCB and it might work you just need to do some exploring
Try using a multimeter (if you have one) on the 6 pin connecter where the wire goes
Old 06-20-2004, 11:33 PM   #9
Intec 7.2 inch display
The pots are for volume, bass, treble, brightness and color.
Does this give you any ideas?
What should I measure at the pins, I mean would I be able to measure anything on a digital signal?
Old 06-21-2004, 04:14 AM   #10
Registered User
Skraggy_uk's Avatar
Skraggy_uk is on a distinguished road
I bought a Joytech 7.2" PS/2 screen that looked very similar to the ones listed on that site. It was STN. Picture was fairly clear, but text wasn't good. gave up on trying the VGA mod, used it as composite for a while but since then went VGA, then blew up the VGA controller, so I'm back to square one.
4x4 in a turbo stylee.
Skraggy_uk is offline   Reply With Quote
Old 07-03-2004, 12:55 AM   #11
Mehnock,
Any updates man?
I am still in the market for a cheap alternative....Eager to see if you were able to make any progress.
Cheers!
Old 07-07-2004, 11:02 AM   #12
Nahh sorry man I bailed and bought a real 7" VGA screen on ebay.
Now I'm working on getting it in the car.
Old 06-04-2005, 11:23 PM   #13
markland556's Avatar
markland556 is on a distinguished road
omg, could you take a pic for me of the back connector on the lcd, mine pulled out and idk what pins the wires go to.
markland556 is offline   Reply With Quote
PS1 LCD working, but need NTSC timings! e_fractal LCD/Display 27 11-07-2003 12:02 AM
VGA + VIDEO LCD MODULE from www.digitalww.com MaleBuffy LCD/Display 3 08-09-2003 02:53 PM
Standard 10.4 inch lcd Blop LCD/Display 6 07-31-2003 01:09 AM
Installing Touchscreen VGA LCD in Double-DIN and Moving Head Unit smoldyr LCD/Display 10 06-25-2003 07:47 PM
EIO 5 inch LCD help dizzzyduck General Hardware Discussion 3 03-03-2000 08:53 PM
