Old 06-15-2004, 08:10 PM   #1
Danneman is on a distinguished road
PSU to EGG to LILLIPUT ?
How do you connect the egg to the psu (via a molex-connector) to power a lilliput?
Ive searched and found that it should be the yellow and black wires of the molex (psu), but I dont know which of the two wires from the egg should go to which?
MOLEX - EGG
Black - Black
Yellow - Black/White
..or..
Black - Black/White
Yellow - Black
Danneman is offline   Reply With Quote
Old 06-15-2004, 08:41 PM   #2
shchua
You should bypass the egg and connect the Lilliput directly to the PSU. The +12V from the PSU is regulated so there's no need for the egg. Plus the Lilliput egg has a dropout voltage of about 1.5V so you actually get 10.5V on the Lilliput if you connect the egg to the PC's +12V output.
shchua is offline   Reply With Quote
Old 06-15-2004, 08:46 PM   #3
Ok, so I could just cut the plug off an old adaptor, and connect the two wires to the psu.
But which is the plus and which is the minus of the yellow and black wires of the psu-molexes? I still have to get the polarity right, right?
Old 06-15-2004, 09:19 PM   #4
archimense's Avatar
archimense is on a distinguished road
I believe the center connector on the egg is the positive and the outer connector is the negative(I take no responsibility if I'm wrong). But you can check by taking a multimeter and sticking it into your cigarette lighter.
archimense is offline   Reply With Quote
Old 06-17-2004, 03:51 PM   #5
Ok, Ive got it working. The black/white cable is the positive, and the black is the negative. On the psu, the yellow is the positive and the black is the negative.
Old 06-20-2004, 02:45 AM   #6
xmoon is on a distinguished road
Red Wire: 5V
Yellow Wire: 12V
After my lilliput egg regulator got fried, What you are doing is what I did.
I have been testing it for about a week and it works ok
I have Morex Car Power Kit(60w) installed so I can have only one cigarette adapter to power carputer, lcd and my Belkin TuneCast II wireless FM Transmitter at the same time.
xmoon is offline   Reply With Quote
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
Using Lilliput Egg to power HDD alvins Power Supplies 6 05-03-2004 10:44 PM
Lilliput cable extension, opus PSU drain AutoInnovations General MP3Car Discussion 2 04-06-2004 10:37 AM
Lilliput +12v PSU...how can it work? MikeH Power Supplies 2 01-09-2004 10:31 AM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
