Old 06-15-2004, 09:44 PM   #1
spyhunter's Avatar
spyhunter
Lilliput gone crazy
Well for those of you that haven't read my writeup on how to install the lilliput in the Tm701l housing then you probably should check it out to understand how i have everything setup.
So i'm driving the other day and noice that the lilly is all blurry. At first i thought it was my eyes going bad, but it turns out it really is blurry. If i smack the side of it, it clears up. Clearly a bad connection, accept i can't seem to find the problem. I pulled everything apart and found nothing wrong. Perhaps its that small din round connector thats causing it. Any ideas?
Alex
90 300zx twinturbo conversion
Epia C3, 512 ram, syntax mobo, 80 gig WD, Mediacar, GPS w/Routis, all behind drivers seat, 7in Lcd Lilliput VGA with Touch, wireless adapter for stumbling, Consult ODB1 adapter and data scanner.
spyhunter is offline   Reply With Quote
Old 06-16-2004, 08:11 AM   #2
samc's Avatar
samc
Damm thats so disturbing. Anyone own a lilliput and have it working more then a month or os?
I would just check all the connections. Did the also check the threads on that flat ribbon cable from lcd to controller?
Mine needs to be updated.
samc is offline   Reply With Quote
Old 06-16-2004, 08:13 AM   #3
wkolodny's Avatar
wkolodny is on a distinguished road
I had to replace the 9 Pin connector when I first got the lilliput. Crappy 9 pin POS. Used a 9 pin serial connector and has worked great ever since. Entering month 2 with my fingers crossed.
Don't Fear The Gurkey
Click here to check out My Setup
wkolodny is offline   Reply With Quote
Old 06-16-2004, 10:21 AM   #4
shchua
I'll second that. That 9-pin mini DIN connector is nothing but trouble. I had a lot of problems with blurry displays that were caused by bad contacts on the mini DIN.
shchua is offline   Reply With Quote
Old 06-16-2004, 04:07 PM   #5
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
I agree with that. I have had similar problems from the mini din connector
antimatter is offline   Reply With Quote
Old 06-16-2004, 06:02 PM   #6
spyhunter's Avatar
spyhunter
samc, long time no see the lilly is great screen for a great price but its not perfect and requires from massaging to get it right. I've had mine in since feburary and this is the first problem
Alex
Old 06-16-2004, 06:20 PM   #7
Clover
Grayscale's Avatar
Grayscale is on a distinguished road
my 9 pin din works great I've had absolutely no problems with my lilliput
CarPC install is starting to come along again...
Grayscale is offline   Reply With Quote
Old 06-16-2004, 06:49 PM   #8
Bobby Digital is on a distinguished road
I cut out the connector and hardwired all the wires together. Perfect ever since (2 months or so). If you're gonna try it though, you should know that a couple of the wires aren't continuous, they cross at the connector (see this thread ).
Bobby Digital is offline   Reply With Quote
Old 06-25-2004, 08:57 AM   #9
spyhunter's Avatar
spyhunter
Bobby thanks for the advice. The mod cleared up the fuzziness. Best of all it almost seems brighter now.
Alex
WTB: BROKEN Lilliput 619! masch Classified Archive 7 12-14-2004 04:58 AM
Xenarc Touch Panel on Lilliput Controller badandy4you LCD/Display 5 06-04-2004 01:54 PM
Writeup Lilliput installation in TM-701L housing spyhunter LCD/Display 65 05-17-2004 07:58 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Lilliput VGA touch panel cracked. Would DigitalWW 7" touch panel fit ? shchua LCD/Display 2 12-11-2003 11:36 PM
