Old 06-25-2004, 03:33 PM   #16
Quote: Originally Posted by vicky_obee
Ok Fresh install of XP and the TOUCH screen software ( Thats it nothing else )
and still hangs for the touch screen part. thou the mose and everything works fine and the CPU useage is 5 % or so...
If the touchscreen USB cable plugged directly into the PC, or are you using a USB extension cable? If you are using a USB extension cable, is it passive or active? Perhaps the USB data/electrical timing is coming out of sync after a few minutes.
Try unplugging and re-plugging in the USB device AFTER it hangs, post results...
'03 Acura TL PC FINISHED!!
MP3CAR
FiSKARZ is offline   Reply With Quote
Old 06-25-2004, 06:50 PM   #17
ddogg_777's Avatar
Am just using WIN XP and the driver software that came along..
That is your problem, download updated drivers from digitalww or somewhere else.
ddogg_777 is offline   Reply With Quote
Old 06-25-2004, 10:19 PM   #18
vicky_obee's Avatar
Well i feel the same that is is a software related issue but am not able to figure out which one as this is the only one that has been attached to the pc. ( i mean no gps, blueetooth or any com or serial port in use as of now ). MOre over i did try ur suggestion of ALT CONT DEL but it give no pop ups of not responding software in the appli. presently working with a software that i downloaded from http://www.egalax.com.tw/Download.htm . DO u have any better version that i can try with..
vicky_obee is offline   Reply With Quote
Old 06-25-2004, 10:21 PM   #19
vicky_obee's Avatar
Hi wel li am not using any Cable extension for this touch screen. its a direct connection...
Old 06-25-2004, 10:29 PM   #20
Banned
eatyummypuppies's Avatar
Do you have Tourette's? Maybe it's just trying to avoid all the haphazard screaming.
eatyummypuppies is offline   Reply With Quote
Old 06-26-2004, 11:00 AM   #21
vicky_obee's Avatar
no And frankly speaking i have no idea as to what is Tourettes......
Old 06-26-2004, 11:40 AM   #22
no1knows's Avatar
haha
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
Old 01-07-2007, 07:37 PM   #23
Fix For Unresponsive Usb Touch Screen
Hey,
If you're getting messages from users complaining that the touch screen feature of their screen stops responding, there is a pretty simple fix.
ISSUE: Touch screen works for a few minutes, but when inactive for 2-3 minutes, it will no longer work.
FIX: Go into Device Manager and expand the USB controllers tree. Look for "USB Root Hub" entries, right click, and choose the power tab. Look in the "attached devices" and determine if the USB Touchscreen controller is attached to this hub (if not, repeat this process on one of the other USB hubs). IF the screen is attached to this port, click on the "Power Management" tab and remove the checkmark beside the "allow the computer to turn off this device to save power". The touch screen will now work as expected, even after being left unattended. You can still use screen savers and utilities that power down the screen.
Also a side note - this screen looks great at 640x480, but is nearly useless as 800x600.
gmctavish is offline   Reply With Quote
Lilliput screen flash lgbr LCD/Display 10 12-13-2005 12:15 PM
Help with Lilliput 7" Touch Screen webnosis LCD/Display 6 03-24-2004 12:46 PM
GROUP BUY: Lilliput TM-701VGT LCD krystar Classified Archive 236 01-16-2004 07:31 PM
Lilliput internals - size of actual screen? - first post:) ScottC LCD/Display 4 10-25-2003 05:29 AM
Anyone know about Lilliput 7" XGA Touch Screen koyoutou LCD/Display 5 10-06-2003 12:37 AM
