Old 06-30-2004, 01:34 AM   #1
xenarc vs Lillipu (size)
I know the Lilliput vs Xenarc is old. But I think I have a new question on it.
I want to know how much the xenarc builds under and over the LCD screen. (not together).
I have a Lilliput but its a little bit to big under the screen so it can't fit in my car. I have to rotate it 180 deg (with Pivot). But I don't like pivot as it takes a lot of CPU.
storm is offline   Reply With Quote
Old 06-30-2004, 05:00 AM   #2
Raw Wave
Confused's Avatar
The external casing on the Lilliput is smaller than the external casing of both the older and latest generation Xenarcs. The Lilliput I borrowed fit behind my dash with about 3-4mm each side, the new Xenarc was a perfect fit, and the older Xenarc was about 2-3mm too big either side.
As for screen sizes, I can't help you there, I haven't taken apart the Lilliput or newer Xenarc, and didn't measure the older Xenarc when I had it apart.
Hope this helps a little
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 06-30-2004, 05:17 AM   #3
Do you have the new xenarc available?
Can you meassure how high the frame is under the screen?
By the way. Have you heard anything from Powerloc about destinator 3 SDK?
Old 06-30-2004, 02:02 PM   #4
Raw Wave
Confused's Avatar
You mean from the bottom of the visible screen to the bottom of the casing? If so, then I can get those measurements for you in hopefully a couple of days
Unless they've sent something to my work email address in the past week and a half, then nope, I haven't heard anything from PowerLOC
Garry
www.aimee.cc
Xenarc direct cause of audio noise- help! shidarin LCD/Display 5 04-19-2008 10:53 AM
What size barrel plugs for Xenarc 730tsv and Audigy NX 2? Mears General Hardware Discussion 6 08-29-2005 06:26 PM
FS: Xenarc 700TSV touch UXGA capable cproaudio Classified Archive 16 01-20-2003 07:38 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 04:11 PM
Xenarc 7" Touchscreen VGA Group Buy. Skippman LCD/Display 144 07-27-2002 11:52 AM
