The MP3car.com Store
Thread Tools Display Modes
Old 06-30-2004, 10:10 PM   #1
vicky_obee's Avatar
My Photos: (2)
Unhappy Lilliput & Win XP pro !!!! problem
Hi guys any solution pls..
I am using &' lilliput with Win XP pro. Installation is fine and xp works fine . but my lilliput touch screen stops working after 1 or 2 mts. I have tried to upgrade to Ser. pack 1 and also the driver for the touch scree. but still the same.
So I switched over to Win 2000 and things work fine .( last 29 hrs or so )
The only prob is i want to use XP and not 2000 ( as this is slow and Tweaks dont make much speed ups )
Any Solution as how to get it working with XP
vicky_obee is offline   Reply With Quote
Sponsored Links
Old 06-30-2004, 11:00 PM   #2
Registered User
My Photos: (0)
I had many problems with the original drivers... then got new ones from digitalww.com. Fixed all my problems.
http://www.mp3car.com/vbulletin/showthread.php?t=21036
shillier is offline   Reply With Quote
Old 06-30-2004, 11:02 PM   #3
vicky_obee's Avatar
My Photos: (2)
Thanx but i have tried this driver too using a fresh installation of XP and the driver from Digital . but still the same !!!
Old 07-02-2004, 12:40 PM   #4
My Photos: (0)
Exclamation All Windows Updates Done?
You said you installed SP1, um...did do do the REST of the Critical Updates?!
yuprules is offline   Reply With Quote
Old 07-03-2004, 03:41 AM   #5
vicky_obee's Avatar
My Photos: (2)
well all of them....
Old 07-03-2004, 03:43 AM   #6
vicky_obee's Avatar
My Photos: (2)
well all of them... but the funny part is when i use win2000 it works fine. its only that with xp the touch part is not working...and win2000 is pretty slow to boot and ready for work.. since tweaking is not very effective...
Old 07-05-2004, 07:16 PM   #7
d_sellers1's Avatar
Vehicle: 2000 Ford Taurus & 2001 Ford Focus ZX3
My Photos: (0)
I'm running Windows XP Pro SP1 and everything works fine for me. The computer that it's running on at the moment is my server so it hasn't had a monitor since initial setup. I plugged the LCD in and I could see.
Brainstorm: Did you hook up the USB cable before putting in the driver? Alot of stuff (my MP3 player and the Extigy are the same) need to have the driver installed before plugging in the reboot (restart for best results first). After the driver is installed then the computer should be able to use the device. I would remove the driver through device manager, disconnect the TS, install driver, reboot, then plug in the TS.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 07-05-2004, 07:23 PM   #8
brooksware2000's Avatar
My Photos: (0)
Derek
I would also recommend what is stated here. Right click on My Computer and go into device manager under USB devices and check for a splat (Yellow exclamation point). If there is a splat, remove the device, uninstall the drivers and reboot. Reinstall the drivers and install the touchscreen USB adapter. If all is well it should work.
I have had USB devices shat my whole HDD because I installed it before installing the drivers.
brooksware2000 is offline   Reply With Quote
Old 07-05-2004, 09:12 PM   #9
vicky_obee's Avatar
My Photos: (2)
Hi Well tried this stuff alreay. theres no yellow Splat !. and Well let me re phrase the problem. The LCD works fine .. its the touch part that stops responding in a few seconds. Have even tried to disable the ps2 mouse( just in case it has aconflict with touch screen ) but of no help. and while in th same config. of machine and win 2000 the touch part works endlessly..... now where do i stand ???
Sponsored Links
vB code is On
Trackbacks are Off
Win XP start up screen asci01 Software & Software Development 7 06-25-2004 10:12 PM
Is 848 X 480 possible in Win XP? STI_FFY LCD/Display 5 04-25-2004 04:48 PM
Lilliput LCD, 2000 Celica GT and voltage problem Goose LCD/Display 15 12-29-2003 04:53 PM
weird problem with lilliput durring bootup (with pic) djrkd LCD/Display 2 11-05-2003 03:01 AM
Win XP Hibernation and USB Mass Storage leenas Software & Software Development 13 10-28-2003 05:34 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
