Old 07-13-2004, 12:13 AM   #1
Plinkey is on a distinguished road
Double Din Kit for LCD Mount?
http://store.thedishman.com/2004e-sisha1566b.html
Anyone ever try to use anything like this to mount an LCD in dash. I have a car that has two single dins with about 5mm of space between....what do you guys think about this fitting?
http://www.personal.psu.edu/users/z/l/zls106/das1.jpg does that look like a double din size (if i was to remove the spacer between, or is there too much space between the two dins?)
-Plinkey
Plinkey is offline   Reply With Quote
Old 07-13-2004, 10:57 PM   #2
Come on...anything?...anyone?...someone had to have tried this so that you could move the lcd when you get a new car....
-Plinkey
Old 07-13-2004, 11:27 PM   #3
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
You could be the first.... give it a try, be a trend setter.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 07-13-2004, 11:41 PM   #4
I think that i may have too. Apartently im the only one here that doesn't plan on keeping my lcd in the same car forever.
-Plinkey
Double DIN mutilator General MP3Car Discussion 69 08-23-2009 06:36 PM
DIN and Double DIN Dimensions/Standards kubark42 General Hardware Discussion 15 08-05-2009 02:39 PM
Can double din hold pull out and radio? jnusaira Fabrication 12 06-08-2004 04:32 PM
2004 WRX STI, use Xenarc? DWW kit? How to mount? Anyone with a STI? quinxy LCD/Display 15 03-03-2004 12:53 PM
Can 7" touchscreen fit in double DIN opening? RDaneel LCD/Display 22 02-26-2004 02:53 PM
