Noise in Lilliput from HDD
Hi,
I have Lilliput installed into my dash and PC in the trunk connected to monitor with VGA extender (normal, single shielded), when hdd is doing smthing, image is affected by this, its, making some noise in sync with HDD, when HDD is idle (on, but not searching) image is clear.
what do you thin the problem is? is it a good VGA cable needed (thick triple shielded)? I have temprarly removed the lillput regulator it has on the power cable (I have burnt it), maybe this is the problem? Maybe VGA cable is close to power cable (but image is behaving only when HDD is acting).
did anybody have a same problem?
'93 Opel Vectra A with Custom Dash with 7" lilliput
VoomPC/M1-ATX/M10K/256 RAM/20GB 2,5' HDD/Gemtek USB Radio/WinLite/RoadRunner
http://zvi.home.ge/pics/?dir=vextra
