this might help others, this is what I have found so far:
you have a SatellitePro 470CDT
with:
Display Type: TFT Active Matrix Color (800 X 600 resolution)
Size 12.1” Diagonal
Dot Pitch .30mm x .30mm
Contrast Ratio: 100:1 (min)
VIDEO
Memory: 4Mbit EDO DRAM, 3.3V 2 MB
Speed: 50ns
Hyper Page mode support: Yes
Controller Chip: C&T F65555
Data Bus Width: 64-bit
PCI Bus Architecture w/burst mode Yes: 32-bit, 30 MHz
Graphics Accelerator: Yes with 64-bit BitBLT support
full specsheet is
here
spare parts here
http://www.sparepartswarehouse.com/t...A1255U-T2C.asp
and here
http://www.impactcomputers.com/toshi...-hardware.html
from that last site it looks as if all you have to do is cut the "LCD HARNESS - P000236180" and extend it about the 2 feet that you want and also note the picture of the "Toshiba 12.1" TFT COLOR LCD DISPLAY" it looks as if it has another two wires that will need to be extended.
