Old 07-19-2004, 05:29 PM   #1
SAScooby's Avatar
Display OBD info on Serial LCD ? is this possible
Hiya all smart people !
I am dreaming of a new carputer feature
Since some of us have OBD interfaces and I will soon, as I am waiting for my local supplier to get me deltadash from ecutek, living 10 000 miles from civilisation sucks I want to know if I can display the Deltadash parameters on an lcd while I have Frodoplayer or ME running as the main application.
I have looked at matrixorbital / lcd smartie / lcdc etc and I think its possible but how would I get the info from Deltadash to the LCD application ?
Then the next bit is i would like this info displayed in a HUD
Which LCD / VFD should I get ? and has anyone else done this ?
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 07-19-2004, 09:58 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
I'm curious about this myself, as I'ld like that.
Ideally, using a function to change the LCD so it runs through stats from ODB-II (engine stats, temps, realtime mileage, etc.) on an LCD/VFD.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-20-2004, 01:49 AM   #3
SAScooby's Avatar
yip
exactly and perhaps to display it on the windshield as well and then perhaps scroll the song / radio station every few seconds as the vga monitor will be displaying visual effect or rearview cam / bumper cam etc
Old 07-20-2004, 02:35 AM   #4
Leddy's Avatar
Anything is possible, it's just how much time and money you want to devote to the project.
With that in mind, this project could definitely be done. You will need a firm understanding of ODBII and it's protocols. Once you do interfacing it should be "fairly" simple.
The only VFD's that I've come across(I wasn't looking) were crystalfontz.com The disadvantage would be that all chars would need to be reversed be cause of the mirroring of the image to display on windshield. No character LCD's I have run across support more than 8 custom characters. This doesn't even allow for 0-9 to display digits. Since you have or plan to use a pc I'd recommend an off the shelf scan tool for this type or prect as it's the easiest and cheapest route. Learning curve is GREATLY reduced too
2001 Pontiac Grand Prix GTP Sedan (Sold)
2007 Scion tC
WhereIsMyGPS.net Online Tracker
http://www.cardomain.com/id/leddy
Leddy is offline   Reply With Quote
Old 07-20-2004, 06:35 AM   #5
SAScooby's Avatar
hmmm
I plan using Ecutek delta dash, getting it to display on my pc is easy, getting the info from delta dash to the lcd is were I see a problem
Widescreen LCD touchscreen display TheDaWg-0220- LCD/Display 0 01-05-2004 10:57 PM
4x20 or 2x16 Backlit serial LCD for under $40! gkli LCD/Display 1 06-20-2002 08:44 PM
LCD serial interface? Bj General Hardware Discussion 7 03-15-2001 04:55 PM
Looking for Display 4x40 or LCD? Squeeky General MP3Car Discussion 4 01-16-2001 03:21 PM
Need plugin for Crystalfontz LCD (serial), help? mbowler General Hardware Discussion 0 07-27-2000 04:20 PM
