Old 07-20-2004, 04:26 PM   #1
Lazyboy62's Avatar
Lazyboy62 is on a distinguished road
Connecting 2 x 7" TFT to Epia ITX Please help..
I have a problem running 2 TFT on my Via Epia Mini -ITX at the same time !
When I connect my new 7"tft Touch screen to the VGA, its running !! (cool)
But if I also connect the "old" 7" TFT to the svhs, and set Bios to :
CRT+LCD or CRT+TV
The first TFT (VGA) shuts down !!!
I only get the "Windows-startup" picture !!
LazyBoy
Lazyboy62 is offline   Reply With Quote
Old 07-20-2004, 04:35 PM   #2
yunusyu's Avatar
yunusyu is on a distinguished road
I am kindof confuse-maybe you need a special splitter for the 2 rca (tft) monitors
DICE Los Angeles
yunusyu is offline   Reply With Quote
Old 07-20-2004, 04:39 PM   #3
nl4jy is on a distinguished road
Check your display properties... Make sure your resolution and refresh rate is correct for both. It might use the refresh rate of the S-Video line and cause the VGA line to go out of frequency.
The Windows startup uses 640 resolution so 99% of the time it would work.
nl4jy is offline   Reply With Quote
Old 07-20-2004, 04:54 PM   #4
b_nom's Avatar
b_nom is on a distinguished road
have you enabled both of the outputs on windows display properties?
'96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
'00 Jeep Wrangler - planning stage
What can BROWN do for you?
b_nom is offline   Reply With Quote
Old 07-20-2004, 05:28 PM   #5
Lazyboy62's Avatar
Thanks...
I will chek the refresh rate, and the display properties... later... !!
Old 07-21-2004, 02:41 PM   #6
Lazyboy62's Avatar
It's no good what ever I try !!!
Every time the second tft is connectet to the Svhs or the RCA
The VGA TFT turns off !!
I am not abel to adjust any thing, regarding to refresh rate !!
What ever I noticed a "bigger" picture when using RCA con. TFT.
I am using a VIA EPIA M10000
LazyBoy
Old 07-22-2004, 01:28 AM   #7
Plinkey is on a distinguished road
I dont really have any exp. with those MB, but in windows you need to adjust the display props. to either clone, or extend desktop onto the second monitor. ..display props, advance.
If that still doesnt not work, you may need to get new drivers for you epia motherboards display adapater. It is possibly that you never installed the xp drivers when you set up the system...or maybe you just got it (the motherboard), who knows. Anyways, try that and report back.
-Plinkey
Plinkey is offline   Reply With Quote
Old 07-22-2004, 01:36 AM   #8
Sway's Avatar
Sway is on a distinguished road
you could use a program called TVTool and set it to clone. Thats what i use.
Sway is offline   Reply With Quote
EPIA on board gfx + 7" widescreen LCD = problem? phoTToniq General Hardware Discussion 18 06-23-2004 08:12 PM
Need help selecting a 7" TFT LCD for <$200? prospero LCD/Display 22 04-06-2004 10:33 AM
In-Dash 7" MOTOR TFT or Lilliput 7" Touch Screen JonX69 LCD/Display 2 03-06-2004 02:22 PM
FS: EPIA 800 ITX Motherboard dr1ft Classified Archive 9 08-05-2003 09:57 AM
Help me with connecting my 10.4 " sharp tft screen to my incar PC hatronics LCD/Display 2 09-25-2001 12:22 AM
