Old 07-25-2004, 05:29 PM   #1
illycut is on a distinguished road
epia M mobo, video driver problems
I setup an in car pc yesterday, and it loaded up fine to 640x480 with 16 colors, then i put in the 4-1 drivers to update everything, and i restart and i get no signal to the screen. Im assuming the resolution is to high or the RCA output is not activated after than update. What can i do to prevent this?
illycut is offline   Reply With Quote
Old 07-26-2004, 03:37 AM   #2
JayKaye's Avatar
JayKaye is on a distinguished road
10 mins ago I updated my M mobo BIOS and rebooted and same thing happened to me. No screen at all.
Worst case scenario would be my BIOS chip would need to be replaced I guess.
I used the 4-in-1 drivers too.
Did you update your BIOS also?
I got the bios from these forums. It was called 'test.bin'. I also saved my old BIOS but I dont see how that could do any good if i cant get into the pc at all.
JayKaye is offline   Reply With Quote
Old 07-26-2004, 04:10 AM   #3
JayKaye's Avatar
I was able to get it working again. I took out the mobo battery and let it sit, then i plugged it back in and it worked.
Old 07-28-2004, 10:18 AM   #4
wait,so you installed the drivers, and then flashed your bios? I guess i'll try that.
Old 07-28-2004, 10:30 AM   #5
The Grinch's Avatar
The Grinch is on a distinguished road
There are options in the Bios for the type of display you are using (ie. CRT and LCD). It may be set wrong. You can try resetting the BIOS as suggested above, or you can try hooking up a regular CRT (normal monitor). Once you're in the bios you can check to see what the default settings for the monitor is and change it accordingly.
Carputer progress meter: [-----|]
Carputer gadget meter: [--|---]
The Grinch is offline   Reply With Quote
Old 07-28-2004, 11:52 AM   #6
yea it seems like the only way to do this is to update drivers, plug in another monitor to make proper settings for the lcd. So much trouble, but o well, im just happy the thing runs without any problems
epia MII 12000 shipping problems? theheel General MP3Car Discussion 3 06-01-2004 09:13 PM
Problems with new EPIA M10000 Setup nirvanades General Hardware Discussion 7 04-30-2004 06:11 PM
FV24 Video problems "wasted space on screen" Mikesz LCD/Display 3 01-05-2002 03:59 PM
Video problems while building computer Maveric General MP3Car Discussion 18 09-24-2001 07:28 PM
web tv video driver Schnitz General Hardware Discussion 1 03-05-2001 09:09 AM
