Old 07-30-2004, 01:00 AM   #1
Jackboot's Avatar
How to adjust brightness etc after molding Xenarc bezel into dash?
For all you guys that have used your bezel in fabricating a custom dash piece (Gork, for example), how do you deal with the screen reverting back to its factory settings since you no longer have the buttons available to push?
For example, the factory brightness setting is 33 but I like to have it up near 90 for better viewing. I haven't quite figured out what makes the screen revert to factory settings, but it occasionally does. It is no problem at the moment because I have access to the settings buttons on the front of the bezel. I am in the process of making a custom dash mount though and will no longer have access to the buttons anymore. How do you all deal with this problem???
Jackboot is offline   Reply With Quote
Old 07-30-2004, 11:21 AM   #2
you can try soldering extensions so that you can have the buttons elsewhere.
or you can fab it so the buttons are still there.
nl4jy is offline   Reply With Quote
Old 07-30-2004, 11:42 AM   #3
cadence117's Avatar
or extend the ir signal and use remote..
all these solutions are already on the forums, search people
mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
Total = $746....Carputer = Priceless
cadence117 is offline   Reply With Quote
Old 07-30-2004, 03:00 PM   #4
Jackboot's Avatar
The Xenarc doesn't have IR...or else it wouldn't be a problem...
Old 04-25-2005, 04:18 PM   #5
ITL
ITL's Avatar
my 700TSV occasionally reverts to factory brightness of 33 also. I called mp3car store and they deferred to Xenarc.com's support. Spoke to a guy there and he suggested trying a different refresh rate. I've been running 800x600 @ 75Hz...I guess I'll try a different RR for a while and see if I still get this...
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
ITL is offline   Reply With Quote
Old 05-26-2005, 03:45 PM   #6
mine does this too. Anyone got a fix for it?
Bama5150 is offline   Reply With Quote
BMW E46 Custom dash trim for a Xenarc LCD srcstc Show off your project 223 12-10-2007 01:55 PM
Mounting Xenarc inside dash - But removable! Pabs LCD/Display 11 09-06-2004 04:20 PM
Anti-glare and enhanced brightness on Xenarc S4Per LCD/Display 0 04-06-2004 03:35 PM
Using buttons after molding Xenarc MSUC5Vette LCD/Display 1 04-02-2004 09:39 PM
can you donate xenarc lcd bezel? loakster LCD/Display 10 08-11-2003 06:07 PM
