Quote: Originally Posted by Batmanatthenewb
Rando,
My controller died too. Looked at it and there was some indication of the over voltage (compared to the other pictures in this post). I removed the zener and mine still doesn't work. I saw the one side was 5v rail and other was ground. did you just leave the zener off and it worked again, or did you put something in its place until the replacement from Armen got there?
Batman
Once I removed it, the touch kit worked again (albeit unprotected from any kind of power issue). I assume this means the zener fried into a short, or at least a near short. It crumbled into pieces as I unsoldered it. The replacement part was important to restore the limited over / reverse voltage protection.
If your controller isn't working without the zener then I assume you have other issues. It's fairly lucky (in my case) that the zener burned to a short. Once it burns to an open, you'll no longer have any protection and your ICs are next in line to get fried. Check the data sheets on some of those components. They are fairly clear that they cannot survive even momentary spikes beyond 5.5V.
In other words, the zener provides only limited protection and eventually the controller will be killed by errant input voltages.
