Old 08-02-2004, 03:12 PM   #1
Has trouble reading.
sanbas's Avatar
lcd and amp question?
I have a 2001 diamante LS and am going to try to put a 7" LCD where the stock stereo is right now and the extra compartment. Instead of buying a lilliput and removing the case can i just buy a lcd touchscreen from somewhere? I will post some pictures after work of where i m planning on putting the LCD so it will be more clear.
I still have to find a place for putting the new stereo at (maybe in the glovebox, but that might look tacky. I might just eliminate the stereo/ aux. input method and try to do it with an amp...i have no idea on the amp method so input on that would be helpful as well...does my car come with a stock amp i can use already or do i have to purchase a sepearate one?
thanks
sanbas is offline   Reply With Quote
Old 08-03-2004, 08:21 PM   #2
sanbas's Avatar
ok...anyone?
Also is it ok to use a Power Distribution Block if i am going with the amp setup without head unit. That way I wont have to run 2 seperate power cables all the way to the trunk from the battery. This way I can have one power cable going to the trunk to the Power Distribution Block and then split one to opus and the other to my amp.
thanks
Old 08-03-2004, 09:35 PM   #3
check out http://www.digitalww.com/
they have what you need.. Good idea with the amp, just make sure you get a low enough gauge for both your amp and opus. Remember WAV! watts = amps * volts
for the main fuse. good luck.
fakeinator is offline   Reply With Quote
Old 08-04-2004, 10:49 PM   #4
sanbas's Avatar
ok thanks any other suggestions?? regarding brands or thypes of amps. I have a total of 8 speakers on my car.
2 on rear
2 on front door
2 on top of front door (tweeters)
2 on dashboard
Will a 4 channel amp work?
Old 08-05-2004, 12:35 PM   #5
Personally, I am not sure about the amplifier or I would offer a sugg.
That said, this question would probably be much better answered in the Audio section, rather than the LCD section. Repost the question there. Good luck!
slushieken is offline   Reply With Quote
switched +12V for LCD, amp & opus? Saurk Power Supplies 3 07-22-2004 05:10 PM
5.6" LCD, PCI TV/Radio, 7.1 sound card, Sony amp & more eatyummypuppies Classified Archive 22 06-29-2004 08:19 PM
FS: 7" Motorized In-Dash LCD w/ TV Tuner 1300mer Classified Archive 2 06-22-2004 05:12 PM
FS: LCD Controllers - $90.00+shipping infrared Classified Archive 98 07-20-2003 09:30 AM
Having problems running audio from my Shuttle to my amp 0din General Hardware Discussion 3 06-19-2003 02:41 AM
