Old 08-08-2004, 05:13 PM   #1
muldrick's Avatar
Audio noise, only with Lilli LCD on.
OK, donnt yell at me. but I didnt find any threads on this: I have all my audio noises gone except I have a buzzing noise with the Lilli on only.
The screen is installed into my cluster, in front of my speedometer (I use the GPS for a speedo).
My PSU and inverter are grounded. I am running power for the Lilli LCD to my fuse box. (12 V with the egg) I have tried different fuses and ran it straight from the battery. Still have the buzzing noise through my stereo. I am running wires from the PC sound card to my head unit "audio in". Regardless, the buzz is only with the LCD on.
I do plan to get an Opus sometime and run the Lilli power from that, but for now I'd like to get rid of the noise.
Any help????
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline   Reply With Quote
Old 08-08-2004, 07:41 PM   #2
One of my noise problems I have is that, the same for me. When I switch on the Lilliput and engine is running, noise, but when I switch off or stop the engine, no noise. ????????????????
windalo is offline   Reply With Quote
Old 08-09-2004, 02:21 AM   #3
The noise you are hearing I BET comes from the lilliput power egg. Its a piece of **** and needs throwing. I thought i had suddenly developed alternator nise until i realised it the stupid little egg. lol
live2themaxuk is offline   Reply With Quote
Old 08-09-2004, 11:10 AM   #4
muldrick's Avatar
Since I use an inverter, I decided to use the Lilli AC adapter. Now the noise is gone AND the LCD is much clearer
Old 08-09-2004, 02:59 PM   #5
i have that sound too...i might try switching to a different way of powering it...
do you think it could be the screen emitting emi? cuz i get sound from speakers too
aznblueeboi is offline   Reply With Quote
Old 08-10-2004, 11:26 AM   #6
muldrick's Avatar
I don't know. I was gonna switch to the Opus PSU, but now I'm worried I'll get the noise back
Old 08-10-2004, 11:56 AM   #7
Noctris's Avatar
Hmm.. i Wondered about that aswell.. I sometimes have really poor quality on my Lilli.. What is the egg for anyway ? can't I just cut it out between ? Or does it server an important purpose ? Can I replace it with something else ?
I'm going to hell, who's comin' with me ?
Renault LagunaII 1.9 CDI
Carputer Install Progress: [*********-] 90% - Cleaning up
VIA-MII10000 - 512MB Ram - 80Gb HD - Lilliput - GPS - OPUS 150Watt
Noctris is offline   Reply With Quote
Old 08-11-2004, 06:45 AM   #8
muldrick's Avatar
The egg (I believe) is a (cheap) regulator to keep volts around 12+. Since a car's volts can be anywhere between 8 to 15+ volts, I wouldn't remove the egg. I have read threads about people doing that without problems, but it seems a little "chancy" to me. Search other threads about it. If you're using a dc-ac converter, I would just use the ac adapter and plug the Lilli straight into the inverter (using the ac adapter). Mine works great now. no noise, no screen flickering.
If you have a dc-dc converter, you can power the Lilli without the egg from the PSU. But you better check other threads on that also...
noise in audio Harvester General Hardware Discussion 8 10-03-2005 07:40 PM
Hard audio quality problem: Noise / Ground loop? Burat General Hardware Discussion 14 09-09-2004 06:08 AM
How to eliminate noise in audio felix99 General Hardware Discussion 4 09-20-2002 11:31 AM
5-inch LCD Flip Monitor With Audio and other misc stuff. nolmscheid Classified Archive 4 02-20-2002 06:39 PM
5incd lcd with audio dizzzyduck Classified Archive 4 01-24-2001 01:14 PM
