Old 08-09-2004, 12:07 AM   #1
Swell Guy's Avatar
Unhappy Xenarc Alignment Problem
I've got the Xenarc TS and often during boot, the screen shifts right about 50%. It'll flash normally aligned at 800x600 (the Windows setting), but then it'll shift right almost immediately upon boot and say something like 720x480. I don't know what is causing it, I've set my horizontal adjustment on the screen to 50. Mind you, it doesn't do it 100% of the time, just often enough that it's annoying. Reboots don't seem to help, it's unpredictable. Sometimes, reset of power (unplug) on screen helps.
Running the screen off battery 12V (unregulated), and computer off my extra AGM battery via inverter. There's an isolator between the 2 batteries. I also have a 6' VGA extension hooking to the carputer.
Bad cable? I've tried shaking the connections, seems solid. Need regulated supply? Again, intermittent problem, so I don't think it's either. Difference between voltages on the batteries? Maybe...
Hey, what res are you guys running at? I'm at 800x600 and run either Media Engine, MediaCar, or FrodoPlayer right now, but am testing out various other options.
Thanks in advance.
-Ed
~Swell Guy~
Via Epia MII10000 .5 Gb memory, 60 Gb HD, Xenarc 7" TS, inverter power (for now)
Swell Guy is offline   Reply With Quote
Advertisement Sponsored links
Old 08-11-2004, 05:38 AM   #2
hi
i'm having also a xenarc 7" ts and the same problem from time to time, but when i select autocalibration in the menu the picture gets to it right position
Humpty dumpty was a big fat egg
flaakesk8 is offline   Reply With Quote
Old 08-11-2004, 06:17 AM   #3
stimps's Avatar
This happens to mine also. I think its normal. Its the auto calibration automaticaly finding the best spot for the picture.
stimps is offline   Reply With Quote
Old 04-02-2005, 02:35 PM   #4
Raw Wave
RoyN's Avatar
I've seen the other relevant threads I've seen on this...
Mine has a similar problem but auto-resize doesnt go to the correct position, always going to the same WRONG position!
This is an intermittent problem, and it seems that if I wiggle the connection for VGA/touch and/or turn the xenarc off/on it will then auto-size correctly...
Any ideas for this? it really ****es me off, even though it only happens about 2x/week
RoyN is offline   Reply With Quote
Old 04-02-2005, 02:38 PM   #5
kmcniece's Avatar
I had that problem with my crt as well.... and the Epia Motherboard.
I went into the bios and checked the settings for display type. I made sure it was set for the right type of monitor. That fixed it.
If you are using the LCD, try changing that and setting the right resolution....
Good Luck and let us know.
EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
Status:
Installed & Working....
Custom enclosures
Newbie Guide
kmcniece is offline   Reply With Quote
Old 04-02-2005, 02:40 PM   #6
Raw Wave
RoyN's Avatar
Resolution in the bios??? Maybe that is an Epia option, I'm running a regular ASUS mobo socket A with an Athlon
Old 01-06-2006, 10:08 PM   #7
This is old thread but I've been having this issue from time to time since installation in September. Now it's just getting to me because it seems to happen more when someone is like "HEY SHOW ME YOUR CARPC"; I show them and bang shift to the right; then I struggle to explain that it's a computer and I use the remote to auto adjust it back into alignment .
Has anyone found a permanent fix for this? I run it at 800x600 as my default and I have the Epia 12k motherboard.
Thanks,
Chuck
chuckster is offline   Reply With Quote
Old 01-07-2006, 10:33 PM   #8
Hark's Avatar
same here, only when I show it off.
Hark is offline   Reply With Quote
Old 03-18-2006, 10:13 AM   #9
jimothy's Avatar
I've got this same problem - has anyone found a fix yet?
I can set it correctly using the AutoDetect feature on the Xenarc onscreen menu, but the problem with that is that my buttons are hidden by my bezel - so at this point my bezel is just loosly on since I have to take it off every time I need to reset my screen.
I'm running a MII12k with onboard video (i.e. not native res).
Does anyone know if this still happens when using an external video card at native resolution?
jimothy is offline   Reply With Quote
Old 12-19-2006, 09:02 AM   #10
Same problem here, ~2 year old xenarc 700tsv, only seems to happen on reboot, I can hibernate as many times as I want.
BMW 325i -01
Computer hardware:
VIA Epia MII 10000 Nehemiah 256MB/160GB
Casetronic Travla C158
Gain 7" TS
USB GPS
Opus DC-DC 150W
Software: Frodoplayer and Mapmonkey
Sound system: Front kit: DLS UP6, Rear: DLS 425 Powered by DLS RA40
Tomas- is offline   Reply With Quote
Xenarc direct cause of audio noise- help! shidarin LCD/Display 5 04-19-2008 09:53 AM
Xenarc LCD and AV2 Input problem DjBac LCD/Display 4 03-24-2006 02:12 PM
Xenarc TS driver problem Sunglassesron LCD/Display 0 05-14-2004 02:52 AM
Strange problem powering xenarc from 90w Opus :( Brettster LCD/Display 3 05-11-2004 05:19 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 03:11 PM
