Old 08-09-2004, 11:39 AM   #1
The Grinch's Avatar
Changing the Lilliput Din connector to a ribbon cable...
In search for a solution to getting rid of that funny din connector because of my in-dash kit issue, I thought about changing it to a ribbon cable. I saw a thread here where the guy had done just that and it looked like it worked. I'm just wondering if there would be any kind of interference issues with running 8 or 10 inches of ribbon cable? The ribbon cable would be carrying both the VGA and touch screen data. The din cable would end up wiring up to the end of it.
Carputer progress meter: [-----|]
Carputer gadget meter: [--|---]
The Grinch is offline   Reply With Quote
Old 08-10-2004, 12:55 AM   #2
The Grinch's Avatar
No one knows? Hmmm, I guess I will have to be the guinea pig then. lol
Old 08-10-2004, 02:22 AM   #3
darkhalo's Avatar
i did it when i built my first indash mod. I used an old floppy cable and ran the vga cables along with the 2 rca composit inputs. i don't remember how many cables it was exactly but it worked just fine. there is no reason why you would get inaterfierance.
this is the only pic of my project i could find.
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
darkhalo is offline   Reply With Quote
Old 08-10-2004, 09:33 AM   #4
The Grinch's Avatar
Thanks for the reply. I think this will completely solve my wiring issue. The only fear I have is the ribbon cable bunching up side, but I think I can get it to work.
Old 08-11-2004, 12:07 AM   #5
The Grinch's Avatar
Ok, I took the plunge today and replaced that thick video cable that was jamming up the in-dash kit with a floppy drive ribbon cable. I've got pics if anyone wants to see. (I haven't uploaded to the PC yet.
Everything went pretty smooth and the monitor is still alive. But one thing I noticed is that the picture doesn't seem quite as crisp as before. It looks like I'm getting a little ghosting. I also noticed some very faint diagonal lines when the screen is black (like a DOS screen). I'm wondering if the 28 guage from the ribbon cable is not quite heafty enough to carry a good clean signal. Can anyone comment that has a little experience?
Old 08-11-2004, 12:13 AM   #6
lawrence's Avatar
may try a space between the monitor cable with one unused lead and then ground the unused lead.
--------------------- vga
------------------------------ground
---------------------vga
----------------------power
may provide added shilding for cross talk on wires
lawrence is offline   Reply With Quote
Old 08-11-2004, 12:58 AM   #7
The Grinch's Avatar
That's an idea. It will definately widen my ribbon cable. I was hoping to not have to go that route.
Anyhow, here's a bunch of pics.
Old 08-11-2004, 10:29 AM   #8
The Grinch's Avatar
I got to try my screen in daylight today and I noticed that it is also unusually dim. I'm not sure if that's due to the 28 gauge wire from the ribbon cable or not, but I'm not happy with the results. I think I will try the suggestion above and maybe try to find something better than 28 gauge.
Does anyone else have suggestions?
Old 08-11-2004, 11:00 AM   #9
darkhalo's Avatar
i think its all in your head man, all screens look ****ty in the sunlight. Did you ever test your original lilliput in the sunlight?
It looks like you did a good soldering job.
The only thing i did differently than you is that i solderd the ribon cable directly to the controller board.
hope this helps
S2000 Carputer
Old 08-11-2004, 01:34 PM   #10
The Grinch's Avatar
Yes, I have tested it in sunlight before. Today I had a bright white t-shirt on and that might have played a roll.
Some of it might be in my head, but I can tell that the clarity has suffered slightly. As I mentioned earlier, when the image on the screen is black, you can see a couple of diagonal lines going through the page. I don't ever remember seeing them before. And there is a bit of ghosting that wasn't there before.
The reason I didn't solder the ribbon cable to the board was because I didn't have enough slack. I've actually bought 4 feet of coloured ribbon cable today, and I'll probably swap it over to that soon.
I'm also thinking of doubling up on the VGA signal to provide a larger pipe. Comments?
--------------------- vga ]____
...and in an attempt to make even more work for myself, I'm also thinking of getting a better VGA cable, and run the touch screen USB via it's own cable. I'm probably creating more work for myself, but I like to tinker.
Old 08-12-2004, 04:45 PM   #11
FreeDrive Creator
CdRsKuLL's Avatar
I did one ages ago.. its been scrapped now.. info is below
http://www.cdrpro.co.uk/carputer/lilliput.htm
cheers
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 118 10-05-2008 06:47 PM
WTB: Lilliput ribbon cable clips eatyummypuppies Classified Archive 1 07-24-2004 02:46 AM
RE: New Lilliput - Ribbon Cable Problems 047025n LCD/Display 7 06-30-2004 05:21 PM
need lilliput ribbon cable cybermob2 LCD/Display 6 05-21-2004 09:17 AM
WTB ribbon cable for Lilliput nthai Classified Archive 2 05-16-2004 08:48 PM
