Old 08-11-2004, 07:25 PM   #1
It's not really that small...No, seriously.
judoGTI's Avatar
Question Lilliput overrange through BIOS then fine?
Is this normal?
I set the BIOS res to 800*600 and the type to LCD, now I get 'Overrange' through the post until XP starts up, then I get an image.
I guess it works, but if I ever need to get into the BIOS, I'll need to pull the MB battery to reset it.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Advertisement Sponsored links
Old 08-11-2004, 09:34 PM   #2
judoGTI's Avatar
Evening bump
'02 GTI
Old 08-11-2004, 09:38 PM   #3
Raw Wave
rando's Avatar
I get the same thing only it usually happens between the BIOS and the XP login screen. Ocassionally it occurs all the way through the BIOS until the login screen. I've tried pretty much every BIOS settings with no apparent impact.
2004 4runner
rando is offline   Reply With Quote
Old 08-11-2004, 09:42 PM   #4
darkhalo's Avatar
same here, i get the over range screen usually when switching from bios to xp boot.
I also get the overrage screen in windows when i change resolutions quickly. like when i try a resolution and then revert to the previous one in a matter of seconds.
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
darkhalo is offline   Reply With Quote
Old 08-11-2004, 09:49 PM   #5
Doing better than me...
I dont even get an image until I get into XP. Before that, it's a Jurrasic Park image (I dont know why) with some white fuzzy stuff...
digglerd is offline   Reply With Quote
Old 08-11-2004, 09:58 PM   #6
JayKaye's Avatar
try setting the BIOS to CRT + LCD and the other setting to PAL. Thats what I got and it works fine. (800 * 600)
Car PC v1 - 1999 - 2000
DOS 6.22 - MPXF - 2x16 LCD - 6.4GB
Car PC v2 - 2002 - 2006
XP - 7" wide/touch - GPS - Tank batt relay - 100GB
Car PC v3 - 2008
XP - 7" wide/touch - GPS - 802.11g - FM/XM - OBDII - WWW
[||||||||||||||----] 80% complete
JayKaye is offline   Reply With Quote
Old 10-11-2005, 11:15 AM   #7
i can not reinsall the OS in the car, as my lilyput 8inch ts says overrange.
untill windows is on properly, annoying
cambo is offline   Reply With Quote
hmm...just fried the "egg" for my lilliput delussional77 General Hardware Discussion 18 11-25-2004 01:50 AM
Media Car not responding... Lilliput problem? carpcnoobie MediaCar 3 09-01-2004 02:38 PM
FS: Parting out Lilliput 047025n Classified Archive 17 06-26-2004 08:52 PM
Lilliput Dimensions? I want to put one in my Acura Legend... Matt Whelan LCD/Display 2 06-20-2004 12:10 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
