Old 08-12-2004, 09:16 PM   #1
S-Video Full Screen
Ok, I have an Emerson 7" tft screen that I'm using the S-Vid connection on. I know it's not going to be as clear as the lilliput or Xenarc, but with frodoplayer it works fine with one exception. The image won't fill the full screen. (see attached image).
It's not just FrodoPlayer, it's all of Windows. The output is from an ATI 9600 and the OS is 98SE. Resolution is set at 848x480 in that shot.
I've tried using powerstrip, but no matter what I try it just re-sizes the image within that area. I need to somehow stretch the screen.
The PC is an old Acer desktop that has no video options in the bios.
Any ideas on what to do? (besides go buy another screen which isn'tan option right now)
-Vlad
VladTheImpala is offline   Reply With Quote
Old 08-12-2004, 10:09 PM   #2
dodgetimes2's Avatar
Have you checked to see if your monitor has a Zoom feature? Just thought I'd ask, many LCDs and CRTs do.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 08-12-2004, 10:31 PM   #3
I'm sorry, and you are....?
frodobaggins's Avatar
Also check if your vidcard offers overscan/underscan mode, you might have it set to underscan.
In the ATI Control Panel for TV you should also have some adjustments for screen size and position.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 08-12-2004, 10:33 PM   #4
darkhalo's Avatar
is that a touchscreen? (i know its not vga)
Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
S2000 Carputer
darkhalo is offline   Reply With Quote
Old 08-12-2004, 11:27 PM   #5
No touchscreen (I wish) I currently use either a touchpad I have on the serial port, or an ATI remote with Girder.
The Screen has three modes, 6:9 6:9 full and 4:3 That's 6:9 showing. 6:9 full only expands it top and bottom, and then off the screen so I actualy lose some. 4:3 just squeezes it in more on the sides.
the ATI has overscan, but when I tried it, I ended up with the same as if I went 6:9 full on the screen. I didn't see underscan but I'll check it again.
Actually, I'm swapping computers with a P4 I have in a Mame cabinet (same video card type) and it's XP too so I'll check the bios on it as well as try PowerStrip on it.
-Vlad
Old 08-12-2004, 11:29 PM   #6
yunusyu's Avatar
install all the drivers first. then goto display properties....settings.....advanced.... and there should be a tab for your card to adjust zoom
DICE Los Angeles
yunusyu is offline   Reply With Quote
Old 08-13-2004, 08:48 AM   #7
download powerstrip. Rightclick on the new icon in your taskbar, go to display settings. Advanced timing. And make the appropriate adjustments. Hell you can even make the screen the native resolution of the LCD if you add a custom resolution (I made mine 848 x 480)
Tr1bute is offline   Reply With Quote
Old 08-13-2004, 08:56 AM   #8
Rub One Out
Motoko's Avatar
if u got a nvidia card u dont need powerstrip.
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 11-19-2004, 10:20 PM   #9
Bodgy's Avatar
I have the same problem. I use an nvidia geforce2. In the geforce settings I went to tv setting and changed the resolution output on rca to 720x480 (16:9 res, was @ 4:3), this fixed it. The problem I am now having is that the bottom half of the image is at the top and visa versa. I can change this with the nvidia settings but it doesn't use these settings after a restart.
Bodgy is offline   Reply With Quote
Old 11-21-2004, 01:45 AM   #10
Bodgy's Avatar
http://tvtool.info was the answer to all my problems, need nvidia card though.
thanks search tool.
[cough]emule[/cough]
VOICE Nav - how NOT to run in full screen mode? S4Per V.O.I.C.E.S 1 06-13-2004 04:09 PM
Alternate Full Screen Mode Sneaker frodobaggins FrodoPlayer 14 06-04-2004 02:05 PM
Media Car video player MatrixPC MediaCar 2 03-22-2004 01:33 PM
Lilliput.. 7" No Full screen ??? Lazyboy62 LCD/Display 0 02-15-2004 01:38 PM
is full screen passible? kalito MediaCar 1 12-22-2003 04:27 AM
