Old 08-17-2004, 08:47 AM   #1
PS1 Screen Computer Specs
I am designing a computer for my car. I was going to originially hook a 2X20 LCD to it but then I saw I can get a PS1 screen fairly cheap. What hardware specs is everyone using (ie. what mobo,video card, ect...) I am trying to get this system off as cheaply as possible. Can I use onboard video for this PS1 screen mod? If so has anyone been successful doing it? If so what was your config?
Thanks for any feedback on this. I wasnt to get started but dont want to buy incompatible stuff.
Matt
chewy747 is offline   Reply With Quote
Old 08-17-2004, 09:02 AM   #2
Raw Wave
Rob Withey's Avatar
I have successfully driven a ps-one lcd from the secondary of a Radeon 9800 Pro with PowerStrip used to changed the frequencies.
Also I have driven it from a Chips 65555 onboard video under DOS, using direct CRT controller reprogramming (custom code).
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 08-17-2004, 09:06 AM   #3
Thanks for the reply. I was kind of looking for something a little older or lower end. I Dont need this to be a gaming machine. But ANY feedback is appreciated
Old 08-17-2004, 05:36 PM   #4
Malenko's Avatar
Its got a good enough resolution to watch movies but its kinda hard to read text unless its a large font. alot of people start with this screen and save up for a bigger and better one
Malenko is offline   Reply With Quote
Old 08-18-2004, 09:44 PM   #5
if you want to use the composite signal (instead of VGA) than any card with vid-out will do but the quality of the output (especially text) will be affected. For VGA, it a bit tougher, i know that you can't use it with most integrated graphic chipset (they don't support powerstrip). do a search in the Psone lcd thread and you should have your answer.
furballz is offline   Reply With Quote
Old 08-19-2004, 12:39 AM   #6
MySQL Error
MatrixPC's Avatar
If you can find one, a Matrox G200 or Millenium with 8MB AGP or PCI is a good one. I am using it with the PSOne.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
any feedback info. on Dynamix 7" VGA Touch Screen TFT ??? xtreamvette LCD/Display 29 04-22-2007 04:19 PM
Green screen on Lilliput TM-701L kandyman676 LCD/Display 16 09-07-2004 05:45 PM
lillyput--all hype?----long review liquid_smoke LCD/Display 0 11-21-2003 11:44 AM
computer theft tracking - PC PhoneHome Question General MP3Car Discussion 9 07-16-2003 03:14 PM
Problems with screen backlight and allen controller setup MikeHunt79 LCD/Display 13 07-02-2002 11:54 AM
