I know it worked before I took it apart! I plugged the ribbon cable to the controller back when I put it in the case. It recognizes the controller when plugged into USB. I've uninstalled and reinstalled the software & drivers twice!
did you plug the ribbon cable in the right connector of the controller? It has 2, and yesterday I nearly put it in the white one instead of the black one...
ribon cables are very touchy (atleast in the lilliput) Try to reseat the cable. You may notice that there is room on the left or the right. Try seating the cable more toward one side
__________________ -Jesus- King of Kings Lord of Lords
Yea... i figured the inards are different but i just know that those ribbon cables and connectors can be finiky. If you didn't drop it or brake anything physically and you didn't fry it by taking jumper cables from your battery and probing the electronics to see how big of a spark you can get, it should be safe to say that it isn't broken and is probably a loose connection or somthing silly
you didn't put your touchscreen in backwards, did you? that would be something silly indeed! Same thing with the controller, your components are facing down to the LCD controller normally, I think.
Hmmm... That's a good question! I was pretty excited to put it back together I just might have....BRB!
