Old 08-24-2004, 07:09 AM   #1
Interesting mounting idea
I've had a pretty cool idea for the mounting for my monitor in the car - see what you think.
Mount the montior on slide rails (use them under the monitor for neatness) and then simply use a small 12v actuator mounted to a riser arm under the dash.
Cut an exit hole in the dash, with a nice cover on top of the montior so when it is under the dahs it's toally invisible and looks nice - you could even wire it through to an opus I presume to activate whenever the PC is activated.
So: Get in car, turn on ignition. Opus or whatever triggers PC and actuator, monitor rises vertically out of dash and the job's a good un. No problems with security as it'll be totally hidden, and no problems with mounting as there is usually a lot more space under the dash than you think. My only worry is the laws regarding having things on your dash obscuring view - but a widescreen monitor is only going to be five inches high, so surely it should be okay?
Actuators can be got for a tenner, and the rest is just thought and design. Plus, how cool would it be??? If it works, I think I may find a way to put one of the centre console for rear passenger viewing too on a manual switch.
Thoughts? Have I explained myself well enough?
Majik
MajikNWA is offline   Reply With Quote
Old 08-24-2004, 07:37 AM   #2
Done a quick drawing to illustrate - sorry if they're a bit big....
TFT down
TFT up
I see no reason why touchscreens wouldn't work for this either.
Majik
Old 08-24-2004, 10:57 PM   #3
binary.h4x's Avatar
whats a tenner?
binary.h4x is offline   Reply With Quote
Old 08-24-2004, 11:40 PM   #4
MySQL Error
jcdillin's Avatar
heh heh, I think thats 10 pounds if i'm not mistaken. I have seen this done in a persons car before and it looked very cool, but he had alot of problems with the sliding part it kept jamming.
jcdillin is offline   Reply With Quote
Old 08-25-2004, 12:32 AM   #5
fantomas's Avatar
i was planning on doing this but i didnt have enough room..
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 08-25-2004, 12:45 AM   #6
cheerio's Avatar
What woudl you do about the hole in the top of the dash? unless your going to add a flap or something that will just go down when the screen dones
cheerio is offline   Reply With Quote
Old 08-25-2004, 12:48 AM   #7
fantomas's Avatar
Old 08-25-2004, 03:44 AM   #8
GingerPrince's Avatar
I saw one just like this a while ago at a car show. It was in a Smart Car! (one of these for any non-europe types that may not have seen them). Tiny little car. The guy had a 17 inch panel that came out of the top of his dash!! It would come either full way for movies etc, or half-way for GPS etc.
The problem? He had to remove all the air-con, and even all the other piping for the standard heater so he had no airflow into the cabin!!!!
Strictly a show car, methinx!
GingerPrince
Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
Carputer Install - http://www.stuffandting.com/carputer/
CarBox Software -- http://www.stuffandting.com/carbox/
GingerPrince is offline   Reply With Quote
Old 08-25-2004, 06:06 PM   #9
Aftaab001's Avatar
i think you are talking about T1ny! I met him here in UK! He is on this forum.
Search for "T1NY "
www.t1ny.com
MG ZR CARPUTER (UNITED KINGDOM)
Aftaab001 is offline   Reply With Quote
Old 08-26-2004, 01:02 AM   #10
Pogi's Avatar
The Rails sounds like a good idea. but insted of using a piston Actuator to move the screen up and down. why not use Tracks, like a tank. like 2. or hell, even one in the middle to Move it up and down. I think that would be easyer. And wouldnt bind up or jam.
Pogi is offline   Reply With Quote
Old 08-26-2004, 03:50 AM   #11
Search for "T1NY "
www.t1ny.com
That's the one!
GingerPrince
Security idea - hide the HU jaeger General MP3Car Discussion 17 08-23-2004 01:17 PM
Harddrive mounting idea.. Custommx3 General Hardware Discussion 14 05-25-2004 12:39 PM
Mounting Idea dummptyhummpty General Hardware Discussion 8 05-12-2003 11:32 PM
Interesting idea maybe? mr0range General Hardware Discussion 2 01-31-2002 12:20 AM
good idea for remote mounting of CD/DVD/HD mprover General Hardware Discussion 2 08-10-2001 02:49 AM
