Old 08-25-2004, 04:28 PM   #1
chewy747 is on a distinguished road
4X40 LCD Diagram
on the diagram from http://skylab.org/~chugga/mpegbox/files/lcd.GIF
What does the line coming off the 100 mean? The one that comes off the center pin and goes to the bottom pin.
chewy747 is offline   Reply With Quote
Old 08-25-2004, 04:58 PM   #2
henriktha is on a distinguished road
It's a 100 Ohm pot ;-)
Car PC: Via Epia M10000N ~ Morex Cubid 2699 ~ M2-ATX PSU ~ 512 MB DDR Kingston ~ G-Sat BU-303 GPS mouse ~ 80 GB Samsung 3.5" hdd ~ Ruwido Wireless IR Keyboard w/mouse keys. ~ 7" - MM400 Touch Screen
www.autopc.dk
henriktha is offline   Reply With Quote
Old 08-25-2004, 06:10 PM   #3
Do I need to solder a wire from one side to the middle of the pot?
Old 08-26-2004, 12:57 AM   #4
GWRedDragon's Avatar
GWRedDragon is on a distinguished road
er...
GWRedDragon is offline   Reply With Quote
Old 08-26-2004, 01:59 AM   #5
Superduck's Avatar
Superduck is on a distinguished road
I think there's a bit too much "pot" going around, if you know what I mean...
I found these links to be much more useful than that diagram. Two of the best tutorials (in my opinion) are:
IceHardware
and
this one
Hopefully one of those will explain it for you.
Whether you need a potentiometer will depend on whether you want to be able to adjust the backlight. You could wire in a switch to change between full power and half power for day/night use, or just use the pot to adjust it to a comfortable level. Either way, check the specs on your LCD. I found my LCD needed 4.4v, while one of the sites said straight 5v is okay. Had I wired it that way, I would have fried the backlight. Check and double-check your specs. I've even had two LCD's from the same manufacturer use different specs.
Good luck,
Kris
Superduck is offline   Reply With Quote
Old 08-26-2004, 02:32 PM   #6
thanks! great links! sorry about the stupid question just a little new
Old 08-26-2004, 03:43 PM   #7
Marsupial's Avatar
Marsupial is on a distinguished road
linking the 2 pins of the potentiometer turns the pot into a rheostat, but it should not be required for correct operation.
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
4x40 char LCD EL backlight & inverter. sell or trade... Jarrod Classified Archive 6 03-06-2002 10:31 AM
(PIC) replace car-tock LCD with a 4x40 for mp3s....HELP!! UNIQUE-CAR LCD/Display 8 05-03-2001 05:42 AM
4x20 lcd, 4x40 lcd with keys, num. keypad RaZor Classified Archive 1 04-17-2001 11:19 AM
Looking for Display 4x40 or LCD? Squeeky General Hardware Discussion 1 01-17-2001 01:25 PM
Looking for Display 4x40 or LCD? Squeeky General MP3Car Discussion 4 01-16-2001 03:21 PM
