Old 08-27-2004, 10:45 AM   #1
jethari's Avatar
jethari
parallel port LCD problem
I'm having problems with my 20X4 LCD module connected to the parallel port of my carputer. The module was displaying junk characters for a while. Then I reset the bios of the carputer to standard defaults. Now I'm only getting the self test blocks on the display, nothing else. The module istself seems to be ok because I connected to my home computer and everything is fine. I checked the status of the parallel port through the device manager - it says " this device is working properly" and that there are no conflicts. I even tried re-installing the parallel port but to no avail. What could be the problem? Can anyone help me?
jethari is offline   Reply With Quote
Old 08-28-2004, 12:44 AM   #2
davesaudio2
did you cycle thru the bios para options ecp epp etc?
davesaudio2 is offline   Reply With Quote
Old 08-28-2004, 03:37 AM   #3
jethari's Avatar
jethari
Yes, I've tried all the combinations - ecp/epp/ecp+epp. There's no change.
Old 08-29-2004, 10:52 PM   #4
davesaudio2
length of cable?
Old 08-29-2004, 11:55 PM   #5
jethari's Avatar
jethari
Length of the cable is less than 6". I'm still testing the carputer on the bench and between the time it was working and the time it stopped, no hardware changes were made.
Old 09-05-2004, 10:56 PM   #6
jethari's Avatar
jethari
Hellooooooooo?!! Anybody there?
EPIA on board gfx + 7" widescreen LCD = problem? phoTToniq General Hardware Discussion 18 06-23-2004 08:12 PM
Problem with the lcd wyrd MediaCar 10 05-30-2004 07:49 AM
Long Parallel port cable for HD44780 Dwiel LCD/Display 2 04-10-2004 07:28 AM
Problem with a 40x4 Parallel Port LCD SuperAJ LCD/Display 17 06-20-2003 08:22 PM
LCD / keypad problem Old El Paso Software & Software Development 0 12-28-1999 04:00 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
