08-29-2004, 07:32 PM
#1
LILLIPUT (what do you expect)
OK this has been redonkulous... and i need to see if this is happeing to anyone else,, the more i use my lilluput,,,, havent even put it in the car yet.... the more problems i have... this is what i have thus far
screens workin reboot its over range.. usually thats if my reolution is too high
then ill reboot and itll work without changing reolution(sometimes)
then sometimes i reboot and as windows starts to boot the screen will start getting white on the outsides,, bright bright white,,, and slowly move towards the middle,, i turn off the screen when this happens as i think it would mess it up,, then when i turn back on it says out of range
and now i cannot even get the damn thing to be in range,, regardless of the variants,,,, refresh rate,, reolution (800x600) wtf ever,,, im starting to get annoyed as when i first got it i thought it was a refurbished one though i have been assured ver many many emails its not( go ☼HERE☼ to see what im talking about , scroll down..
so anyways,, anyone know what any of this **** means!! the main prob i have is the damn white edges,, looks like every pixel is as bright as it could be and slowly moves towards the middle,, i will take a video of it in a sec,, though i cannot host vids ill prob just take a pic of it mid through
PLEASE any suggestions answers ect,,,, thanks fellas luvchu
throw a moon
heuvos vin chevos
08-29-2004, 08:08 PM
#2
any...ones... input 8-(
throw a moon
heuvos vin chevos
08-29-2004, 08:20 PM
#3
i got a vid of it if anyone can host it fur me
throw a moon
heuvos vin chevos
08-29-2004, 08:30 PM
#4
yea im going crazy posting off the chain but im at a standstill until i can get this fixed... i just said chain...
anyways it has done this before on my desktop pc. and it just worked after i rebooted... but i cannot get it to work on my epia m1000 at all now,, i plugged the lilliput back into my regular pc and it worked,, back into the epia,, the white **** again... then my desktop monitor into the epia,, it shows up,, soo,, somehting weird going on,,,, i reinstalled the drivers on the epia,,cant be it though as all i did was reboot,, and nothing,,, i have another idea im about to try... where are all the lilliput pros.....armen 8-(
throw a moon
heuvos vin chevos
08-29-2004, 08:55 PM
#5
Have you tried it with a different PC. What are the results then?
08-29-2004, 09:12 PM
#6
yes... i have... i posted before that i have tried many variants,, and the only thing that will not work (now) is the lilliput with the m1000...... and like i said,, this happened before with my desktop pc but once i would power it off and on it would fix, or reboot,, but now as soon as it goes into windows it does it
was the lilliput supposed to come with any vga drivers?
throw a moon
heuvos vin chevos
08-29-2004, 09:18 PM
#7
With the M10000, there's something you can do that'll help it w/ Lilliputs. If you haven't already, go into the CMOS settings and set the Monitor type from CRT to LCD. It solved the problems you described for me.
#8
Super Moderator
lol. You didn't read his post did you.
I have had no problems with my lili.
Installed.
-GPSSecure- - GPS Tracking
08-29-2004, 09:20 PM
#9
i looked and wasnt able to change ,, but i will try again,, and another thing,, i just found out and i thought it would solve it... if i boot into windows with my desktop monitor connected to the epia then switch to the lilliput it works,, ill change bio settings now ... hopefully
thx thus far guys,, honestly THANKS!
throw a moon
heuvos vin chevos
08-29-2004, 09:25 PM
#10
i couldnt find monitor type in the cmos settings,,,,, older bios?? and now that i rebooted with my dekstop monitor plugged in instead of the lilli it works,, but im sure itll go back to the old way soon,, as this is what happened before... so im going to keep rebooting until it happens again.. because I KNOW it will 8-(!!!!
throw a moon
heuvos vin chevos
08-29-2004, 09:29 PM
#11
Hmmm. I don't know. From the symptoms is sounds like the video is out of range. I know my older NEC 6.5" LCD did this when it was out of range. It would fade to a bright white. I don't have a Lilliput (have a Xenarc now) but I would guess that the lilliput would accept 800x600 @75hz or below. You're certain of the windows display settings? You can't go by what the OSD of the monitor displays. It just tries to adapt to what settings windows is set to. No drivers are needed for the monitor.
08-29-2004, 09:35 PM
#12
yea,, it said out of range a few times,, or the white jAnk,, but for now its working,, only because i booted wth my other monitor plugged in first... im trying to make it occur again,, and see what i did to make it happens,,
throw a moon
heuvos vin chevos
08-29-2004, 10:47 PM
#13
It is DEFINATELY a setting that can be changed on my M10000. In the Advanced Chipset Features area. Here's a shot of where it looks like:
08-29-2004, 11:01 PM
#14
that setting should be in your BIOS settings as Chairboy pointed out. Check your bios revision if it is not and update your bios as needed. I had a similar problem and setting it to LCD fixed it.
Check out my hopefully useful site...
www.hobbybotics.com
It's still under design but it is functional
08-29-2004, 11:58 PM
#15
damn,, sorry didntcheck back to tell you i changed it,im fabricating, netowrking, upgrading, downloading,, wiring,, ect all at the same time,, trying to finish by wednesday,, as i was recently let go from my job and have a few free days,,,,, until i look for a new one,, i wanna finish asap, i wasnt looking hard enough, and yes i wasnt looking under advanced chipset features,, i changed it to crt-lcd,, i have only rebooted 1 since i changed it,, but thus far working fine,
i do have on more question unrelated to the subject and doubt itll getr answered here but might as well shoot for it... i cannot get my pc to network itself ,, my p4 not my m1000..........i shared the hardrive ect ect ect,, when i go to netowrk places and search for pc near me,, it takes 2 minutes to search and then pops up saying "workgroup is not accessible" "the list of servers for the workgroup is not currently available"
im guessing some corrupt files,, missing files ect,, HOPING its not anyone got any ideas?
i appreciate the help guys,,, VERY VERY MUCH SO.. i will now be paypaling 326 dollars to everyone that replied to my thread...
well i would have if i didnt just lose my job,, but still,, i appreciate the help ,, and my appreciation is mucho better than money.. right?
throw a moon
heuvos vin chevos
| Thread Tools |
| Display Modes |
Linear Mode
