Old 08-31-2004, 09:32 AM   #1
hypnootik is on a distinguished road
lcd connection
Sorry for my stupid question but;
how is the lcd connected to the computer? Lpt, vga ???
hypnootik is offline   Reply With Quote
Old 08-31-2004, 09:38 AM   #2
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
Depends on the LCD, if it's larger color graphic LCD it connects to the computer via VGA but keep in mind that not just any LCD panel can be connected to a computer it has to have a controller that enables it connect to the computer. Now if you have a smaller text only LCD those can be connected to the LPT port on your machine and have to run with a special program.
jcdillin is offline   Reply With Quote
Old 08-31-2004, 10:03 AM   #3
yuprules is on a distinguished road
LCD's
Some LCD's are even DVI (think of it as a digital version of the VGA port found on most PC's).
yuprules is offline   Reply With Quote
Old 08-31-2004, 10:41 AM   #4
LCD I am talking about is:
http://www.mp3car.com/vbulletin/lcd-display/31925-ramline-mobile-pc.html
There is a display controller unit PCB 1002B.
The problem is that I can not get it working.
Old 08-31-2004, 11:16 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
All of the above.
The color LCDs designed to be a video monitor are typically VGA or DVI.
Character LCDs or VFDs can be parallel, serial or USB.
If you're talking about the one you have (made in Finland!), it's likely VGA. Typically, laptop (and other smaller-format computer) manufacturers use VGA in a proprietary cable that's smaller than a standard 15-pin VGA connector, usually a ribbon-style cable that's wholly internal, as well as flexible, so it can be used in the tight confines of a laptop.
Hope that helps.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 08-31-2004, 11:34 AM   #6
Yuriy's Avatar
Yuriy is on a distinguished road
It is possible that you will be able to use this LCD with special software, but I doubt it was designed to be used on a PC.
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 08-31-2004, 11:48 AM   #7
4u2n's Avatar
4u2n is on a distinguished road
http://www.mp3car.com/vbulletin/showthread.php?t=31925
Can you get more info
Number from the chip ???
connecter number of pin ????
Plan for project = 100%
Part the project. = 100%
Built...................= 99%
Finish.................= 99%
Install ...............= 99% -50%
Ditail at 4u2n.dk
Here
4u2n is offline   Reply With Quote
Old 08-31-2004, 12:40 PM   #8
There are some numbers.
1. Altera EP610SC - 15 F9513
2. PE - 52627 9533-A
3. M9512AH LM2575N
4. Display controller PCB1002B
5. P6482PA
This connector fits LPT. It has 25 pins.
Old 08-31-2004, 01:49 PM   #9
4u2n's Avatar
Exclamation
3. M9512AH LM2575N
5. P6482PA
1. EP610LC-15 PLCC28, 0.050" pitch DIP24, 0.6" wide W9718
2. Can't find info
3. http://www.xs4all.nl/~lous/lm2575/lm2575exp.html
4. Can't find info
5. Can't find info
1. a chip to program, 2. is a 5 volt power regulator
I think the display is made for secial product, an it hard to find info on it.
I also have some to, where i can't find information
Maybe a day you will find it, Good Lock
Ditail at 4u2n.dk
Here
Old 09-03-2004, 10:24 AM   #10
Still havent found any information.
Is there a way getting it working without specs?
Passing 4.5 volts throu pins didnt make any effect.
Maybe passing 6-12v would?
I dont want to buy new 7" lilliput before makeing sure that
ramline LCD is no use
Old 09-03-2004, 10:34 AM   #11
fakeinator is on a distinguished road
LVD Port
So what is the LVD port found on the VIA mini-itx mobos? It's 40 pin, can that connect directly to the lcd, w/o the vga controller?
fakeinator is offline   Reply With Quote
Old 09-03-2004, 12:03 PM   #12
nl4jy is on a distinguished road
That looks like the connectors on AIX Terminal boxes... They look like LPT ports and the screen are 2 colors.
I could be wrong though, so don't quote me on this.
nl4jy is offline   Reply With Quote
Old 09-03-2004, 12:25 PM   #13
But can I send information needed to run this device throu lpt port with some program??
Old 09-05-2004, 03:42 PM   #14
So I passed 6 and also 12 v throu pins and quess what happaned.
The screen went grey and blue but nothing else.
But if it went blue it means that it is color screen.
Old 09-07-2004, 05:59 AM   #15
Can I use some program to communicate throu LPT port
What is the physical connection of stock LCD 2004 Acura TL? ITL LCD/Display 5 01-30-2006 06:26 PM
Is it possible to use Laptop LCD for VGA connection fn4970mlee Newbie 2 06-15-2004 12:59 PM
Is it possible to use Laptop LCD for VGA connection fn4970mlee Newbie 2 06-15-2004 12:03 AM
Lcd Display - Connection To Multiple Cameras Dluvr22 LCD/Display 2 08-19-2003 10:29 AM
8.4" Touchscreen LCD, 7" Wide LCD & portable DVD player with TV Tuner nolmscheid Classified Archive 4 03-16-2002 02:32 AM
