08-31-2004, 04:26 PM
#1
Auto PowerOn Lilliput
I have put in this tread as to modify the lilliput to have automatic power through Igniton On.
If it is able you' to interest..... link here http://www.mp3car.com/vbulletin/show...1&postcount=51
Bye
Mauri
08-31-2004, 06:40 PM
#3
Quote: Originally Posted by antimatter
And' true, are right!
However if you make the connection as it says him you lose the I use manual of all the buttons of the lilliput (at least with mine it did so) instead eliminating the R. from 10K original and putting to place that from 150k, and' everything ok.
The cond. and' better in SMD and tantalum, however him' and' practically then as also made Coyote.
Better, sign that then it also works to others
Mauri
08-31-2004, 07:00 PM
#4
I see dead kittens
If understand this correctly, mauri's mod makes the lilliput turn on automatically and still keep the functions of the keys and coyote's mod just turns on the screen. If this is correct can someone explain how to do mauri's mod, because I may having a little bit of difficutly understanding, I do not know much about resisters and such.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
08-31-2004, 07:17 PM
#5
I thought Coyote's mod allow the buttons too. The mod that kills your buttons is where you short the contacts for the button so it emulates the power button being held down, that's the one that locks you out of your panel buttons.
08-31-2004, 08:56 PM
#6
I see dead kittens
So what is the difference between mauri's mod and coyote's mod?
Installed
08-31-2004, 11:43 PM
#7
Coyote's was posted 8 months earlier?
SeeYa! -Jim-
09-01-2004, 03:00 AM
#8
Raw Wave
Buttons still work with Coyote's mod!
09-01-2004, 07:51 AM
#9
In my lilliput if I do as had posted coyote all the keys are disabled.
Then you it does as it seems better you.
This way' as I have done me to me it works, as coyotes didn't work the keys.
It looks that I don't have at all to sell the solution of the thing!.
I have perhaps brought simply one experience of mine profit to someone other, then you see you...
09-01-2004, 11:35 AM
#10
Mauri, is it possible that you made an error while implementing Coyote's fix?
09-01-2004, 12:46 PM
#11
No, I have not surely made any error.
Coyote connects a pin of the resistance to l pin of a' other to have the +5v as pull-up.
Me doing so' I have seen that in my lilliput 7" with TS nobody pulsating worked anymore.'
Instead as I have made the change me it works all ok, I understood all the buttons and all the functions of the Lilliput.
PS: the principle and' the same of coyote, only he withdraws +5v from another point that according to me it is not all right.
I have preferred my way as it modifies.
Mauri
09-03-2004, 05:43 PM
#12
Mauri
this and' what happens if you connect as coyote the R from 150k in the point where he says, it holds to tall level the button of power and it disables the others.
As I have done me doesn't happen this and they work all pulsating ones
Bye
Mauri
09-03-2004, 06:41 PM
#13
Well, something is odd. If you'll read the Coyote mod thread, you'll see that there are many people who have succesfully implemented it without losing their buttons.
I suppose the answer could be that they're all crazy and you're the only sane one...
09-04-2004, 04:29 AM
#14
SEE......
Quote:
Originally Posted by leemik
I just got my lilli and I think I killed it within 2 hours but that's a story for another thread..
I was taking mine out of the case and I'm looking at the controller board.. couldn't I just tape or hot glue the power button down?? It seems to work because I taped it and kept turning on automatically when I plugged the power in... :dunno:
--mike
People have said that shorting the power button (keeping it pressed at all times) basically disables all the other buttons on the face but still allows the remote to work for the same functions.
I have not done this, so I can't confirm it... just something some other people noted.
but have you tried to modify the lilliput or no?
I don't say that that doesn't work of coyote, only that a R from 150K connected in Pull-UP to the entrance of a' other R from 10K is able' to produce a stable activation of the circuit of power of the liliput, and and' as if you always reward the button of the power of the lilliput, you will see that the keys don't work.
you make a test: without having made the change, prizes always the key power of the lilliput, and you will see that the other keys don't work, really what happens (at least in my lilliput) if I connected as coyote.
However I apologize me, but another time I won't post' more' any suggestion, sees that ideas are criticized only.
09-04-2004, 05:45 AM
#15
Raw Wave
Mauri, no need to stop your postings! We're just saying that Coyotes method has worked for us and many others. If your way works too then, good, that gives people more choice.
Maybe there's something different on later Lilliputs?....
| Thread Tools |
| Display Modes |
Linear Mode
