Old 09-01-2004, 05:51 PM   #1
Lilliput only uses a portion of the screen
I have a lilliput..non-vga...I know, not the best idea. So when I run my carputer it doesn't fill up the entire screen. I've played with all the settings and there's still a portion of the actual screen that isn't filled up. There's a a portion of the screen on both sides that's roughly an inch and a half that doesn't display anything. Did I miss a setting or something on my carputer?
gambit32 is offline   Reply With Quote
Old 09-01-2004, 06:19 PM   #2
sagekoala's Avatar
overscan?
if you tweaked with your overscaning you might be able to work something out. i have no idea how to do it on a windows box. sounds like something powerstrip might be able to help you with, but idk I've never used it
don't worry i know i usually don't make much sense
sagekoala is offline   Reply With Quote
Old 09-01-2004, 07:42 PM   #3
I'll give powerstrip a shot when I get home. It's also shaking...something that I forgot to mention. I think I can change the refresh rate in powerstrip too.
Old 09-02-2004, 05:43 AM   #4
Raw Wave
Confused's Avatar
The Lilliput IIRC has different "zoom" modes, which can display a 4:3 image (which is what you're getting from the PC) as either normal mode (which is what you're seeing, with black bars down the side) or in "stretched" mode, which is where it will stretch the image to fill the screen.
This should be an option within the menu/remote of the Lilliput
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 09-04-2004, 02:07 PM   #5
Garry
Is that only for the vga models? the 'stretch' 4:3 option? I do have two options for 4:3 but neither of them fill the screen. I'm going to give powerstrip a shot this afternoon to see if that makes a difference.
Old 09-04-2004, 02:09 PM   #6
Raw Wave
kickercivic1's Avatar
what model do you have?
07 Jetta
Carputer:
Voompc-2, Intel 1.33, 1GBram, 60gb HD, Dynamix 8"
Audio:
front Qsd 216
Rear QSD 213
Rockford (2) p2 10" subs
JL 500/1
JL 300/4
Audigy 2 nx
kickercivic1 is offline   Reply With Quote
Old 09-04-2004, 08:17 PM   #7
Mine is non vga...not sure on the model tho..i'll have to find the box.
Old 09-05-2004, 07:12 AM   #8
Raw Wave
Confused's Avatar
AFAIK, that option is only there for AV inputs. (VGA inputs will automatically use the entire screen I think)
Garry
www.aimee.cc
Old 09-06-2004, 01:11 AM   #9
okay it took some tweaking but i got it to where the screen is filled displaying at almost exactly 16:9...i found a thread that mentioned going into advanced settings for the display to get a better resolution. i also had to choose 'underscan' in my cmos settings. that seemed to do the trick. thanks for the help everyone....but vga would still be better.
My solution to Auto Power ON Lilliput screen coyote LCD/Display 264 06-02-2008 04:52 AM
HELP me PLEASE: Lilliput touch screen "No more controller" RS3RS LCD/Display 4 09-01-2004 02:02 AM
Problems with new lilliput touch screen panel? markc04 LCD/Display 2 08-27-2004 02:38 PM
Lilliput FULL SCREEn ericdee LCD/Display 5 05-05-2004 05:18 PM
Lilliput.. 7" No Full screen ??? Lazyboy62 LCD/Display 0 02-15-2004 01:38 PM
