Old 09-14-2004, 06:16 AM   #1
NEO
NEO's Avatar
Auto video switch on lilliput
Any one no how to make lilliput auto switch vga > video1 and back
whid help of the rewerse light
Everyting that has a begining has to have a end
NEO is offline   Reply With Quote
Old 09-14-2004, 06:45 AM   #2
Bravellir's Avatar
It shouldn´t be to difficult to have a pulse generated when the reverse light turns on. The big problem is that the lilliput button cycles thru tree inputs. We had to achieve a way to generate one pulse when reverse on, and two pulses when reverse off.
It will probably be easyer to get this done by software. Use a usb cam and some type of serial controler ( Frodo have done this to disable video when handbrake is off, by using only a relay, and there is already around a small app to display a usb cam window). When reverse light is on, your app would get a usbcam window on top, when reverse off the window would go away
It would be great if possible.
Brave
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status -->
Lilliput Installed (not indash yet..)
BraveCar 2.5
Bravellir is offline   Reply With Quote
Old 09-15-2004, 06:06 AM   #3
Zoltan's Avatar
http://www.mp3car.com/vbulletin/show...84&postcount=2
'03 Escape 4WD:
-iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
-Transflective 8.4"
-XM, iG4, OBD-II (BR-3)
-Rearview camera with auto-switching (modified cheesbox)
-Slim Slot DVD+RW
-RR, DFX 4
Zoltan is offline   Reply With Quote
Old 09-15-2004, 07:53 AM   #4
Confusion Master
Enforcer's Avatar
hard bit is knowing which mode the monitor is in. You can easily get the reverse light to simulate the AV/TV button on the lilliput but as it's a toggle on momentary if you have already manually switched it to TV it will then switch it to VGA.
Enforcer is offline   Reply With Quote
Old 09-15-2004, 11:22 AM   #5
yeh, I trying to figure out the exact thing for my lilli. I heard those cheese boxes are expensive though. This is mostly for cool factor, so I would like to keep the costs down.
I also want to avoid opening the Lilliput up and voiding the warranty.
mykolJay
99 Accord coupe
http://www.geocities.com/accordpc
My Project Thread on mp3car.com
mykolJay is offline   Reply With Quote
Old 09-15-2004, 11:47 AM   #6
Registered User
gork's Avatar
Yes use a cheese box. They aren't too bad -- like 50 bucks. Check ebay. They are sold there from time to time.
Note that the cheeze box outputs 640x480 and my computer is set to use 800x600 -- sometimes the lilliput has problems resyncing. While the computer is booting it's not too bad.. Obviously if you run your desktop in 640x480 you will not have any trouble either..
MY CAR IS FOR SALE!
See My Project Page for Details - 2003 BMW E46 ///M3
Custom Dash Monitor Housing - OEM Fitment
Custom Overhead DVD-ROM Housing in Headliner
BMW I-Bus Integration
My homepage with many other fun projects!
gork is offline   Reply With Quote
Old 09-15-2004, 11:59 AM   #7
Raw Wave
rando's Avatar
If someone wants to poke around their Lilliput controller board with a meter or scope, you may be able to find a signal (or signals) which can be used to detect which mode it's in (VGA, Vid1, Vid2). If you had that, then the cycling wouldn't be so bad.
I've been wanting to do this, but have no desire to rip my screen out of the truck (again) and crack it open. Someone getting ready to do the Cayote mod on their screen would be in a good position to get an answer for us.
2004 4runner
rando is offline   Reply With Quote
Old 09-16-2004, 04:34 AM   #8
Zoltan's Avatar
Is there something cheaper than the cheesbox that does the same thing?
Creative solutions?
'03 Escape 4WD:
-Transflective 8.4"
-Slim Slot DVD+RW
-RR, DFX 4
Old 09-16-2004, 12:14 PM   #9
Registered User
gork's Avatar
Nope. The cheese box is, by all standards, insanely cheap for a scan converter. You might get lucky with something on ebay, though it may not be as easy to hack as the cheese box. I got my cheese box for about $25 from ebay.
One reason the cheese box is easy to hack for this purpose is that the switch that toggles between the VGA pass through input and the composite video input is a cheap DPST manual toggle switch that can be replaced with a 12V DPST relay triggered by the reverse lights. Any other scan converter i've ever seen has an electronic pushbutton 'mode' switch -- and if you could toggle that type of switch cheaply, you could simply toggle the lilliput's video input button instead of bothering with the scan converter in the first place.
MY CAR IS FOR SALE!
need help with lilliput RCA video input CDesigns LCD/Display 9 04-04-2007 07:33 PM
Capture GPS data at the flip of a switch Mr. Inquisitive GPS 4 02-02-2005 07:06 PM
lilliput video 2 vipergda LCD/Display 4 07-14-2004 07:26 PM
How do you save Lilliput video settings? ML430 Input Devices 0 06-10-2004 12:37 AM
LCD video switch for the car Mwilhelm100 LCD/Display 2 11-20-2002 08:03 AM
