Old 09-17-2004, 10:49 PM   #1
Lilliput connector problem? is there a fix?
I've read on this board before how people have had issues with the DIN connector for the Lilliput where the VGA/USB cable connects. People say to pinch the connector because there is a bad ground connection. I am constantly having to adjust my connector and wire due to the screen flickering on and off and it is very annoying. Is there a way to fix this connector or replace it with something more efficient?
tmar89 is offline   Reply With Quote
Old 09-17-2004, 10:54 PM   #2
Raw Wave
Tidder's Avatar
Cut it up and splice it together.
Tidder is offline   Reply With Quote
Old 09-18-2004, 02:43 AM   #3
Mac Car Moderator
kandyman676's Avatar
that is all you can really do....replace the plug with some other connector. I have a problem with my DIN plug causing the LCD to turn green with a short EXACTLY in the DIN plug. I will have to cut mine up and splice it into serial plug ends to make it work.
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 09-19-2004, 05:02 AM   #4
I just got rid of the connector all together and shortened the vga cable.
xtreme_db is offline   Reply With Quote
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
FS: 7" Lilliput Touchscreen VGA Monitor : Broken jaeger Classified Archive 12 08-21-2004 08:46 AM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
How to fix bad lilliput vga connection? chargin LCD/Display 2 07-22-2004 05:27 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
