09-20-2004, 07:41 PM
#1
Toyota Corolla E12 HVAC LCD
I have interfaced all of my HVAC buttons and I am left with the lcd..
I have 2 options.. The easy one and the hard one.. The easy one would be to extend it and custom fit it in front of the shifter!!
The hard part would be to interace it to the PC!!!
It has 24 pins (from which 2 of them are labeled Com1 and Com2)..Is there a way to do it??
09-20-2004, 07:59 PM
#2
Raw Wave
What's an HVAC?
09-20-2004, 08:04 PM
#3
I see dead kittens
Heating, Ventilation, Air Conditioner or climate control
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
09-20-2004, 08:16 PM
#4
I'd usually say it'd definately be really hard, but... that many pins.. it's POSSIBLE that each correlates to something being just set on or off. If it was a character display w/ something like an HD44780 chipset or something, it'd be super tough, but it might be worth hooking a multimeter up to the pins one at a time while it's hooked up and monitoring the voltage as you move the controls around. If all it's doing is completing a circuit to activate the bars on the graph and the individual digit blocks for the numerals, then you should be able to monitor it via parallel port pretty easily. If it's communicating with it through protocol, though...
Question, can you get us a close picture of the BACK of the LCD? Tell us, does it have an IC chip on it? Or do each of the pins go straight to the display itself?
09-21-2004, 06:52 AM
#5
Here is a pic of the back of the board!!
Unfortunately every pin comes from that chip!!
So I suppose it is very hard-impossible???
Would there be a problem extending the lcd's pins??
09-21-2004, 01:48 PM
#6
Wow, looks hard. Hmm... what about CAN BUS? What year is your car? I wonder if the new Toyotas support CAN, and if so, whether or not this data is available on it. If so, you could get access to it and more through a simpler interface.
If not, it might be worthwhile to play with the pins of the LCD like you said, but be careful. Figure out what sort of voltage it's using (probably 5v or less) and play with it.
09-21-2004, 02:23 PM
#7
I don't think about CAN, I haven't heard anything.. It is a 2001 model...
Although in the Car's electronic diagram it mentioned something about CAN...
09-21-2004, 04:45 PM
#8
I'm sorry, and you are....?
What does that chip say on it...
[H]4 Life
I'm a lesbian too.
I am for hire!
09-21-2004, 05:23 PM
#9
188071-2100
-a 0101 R2
Uho 1ja1g
09-21-2004, 05:35 PM
#10
How did you interface your HVAC and to what? Your HVAC has it's own LCD or are you talking about the clock LCD?
I've got an 04 Corolla S, I don't have an HVAC LCD, just the clock LCD which I've replaced all ready...
Thanks for the info!
Toyota Corolla 04
Panasonic 7in In-Dash
Mini-ITX 933Mhz
Mediacar/Mappoint
GPS/MP3/GPRS/Sony HU
2x20 Character LCD
09-21-2004, 06:37 PM
#11
with phidgets kits... And many more functions of the car!!!
I have the Corolla European Version!!
I will have to move the LCD to another place!!(
09-22-2004, 02:05 PM
#12
MySQL Error
Dam the Euro Corolla look much better than the North America version.
09-22-2004, 02:07 PM
#13
Maybe.. It depends on the version!!
Wait until next week, I am fabrication one of the screens!!!
08-10-2005, 10:32 PM
#14
05 Hvac Help!!
Hi Folks,
I want to redo my 05 Corolla S HVAC controls to more compact digital controls, something similar to DjBac. Please help me with any links, any control boards ANYTHING.
Thanks!
11-02-2005, 05:30 PM
#15
I hace a 05 1.4 d4d rolla (european version) to, and I wanna replace the original HVAC LCD (original green sucks...) and control the A/C using the PC ... is this possible without using phidgets ? some CAN or OBDII commands or something ....??
| Thread Tools |
| Display Modes |
Linear Mode
