09-27-2004, 05:15 AM
#1
Vehicle: Vauxhall Calibra 2.0 16v
Lilliput problem - Gain settings seem to reset
Ive got alittle problem with my lilliput, somtimes when i turn it on, my gain settings are all ****ed up, when i do an auto gain setup, its all fine, untill i turn the screen on maybe a day after.
Any help on this problem?
09-27-2004, 05:40 AM
#2
Vehicle: 1993 TX3 Laser
does your lilliput ever experience undervoltage, whenever mine experiences and undervoltage it seams to set all my color settings to 0
Signature: [==||========] 20% complete
09-27-2004, 06:48 AM
#3
Vehicle: '66 Chevy Caprice / '04 Subaru STi
I haven't had gain problems, but my language changed itself and I don't read whatever language it is in.
But to answer your question, I would think Nic is right. Also, make sure that your connections are tight.
________________
______ILL.1______
09-27-2004, 09:24 AM
#4
connections are all fine, running off a 250watt normal PC psu on the 12v line
09-27-2004, 09:29 AM
#5
bump for any more ideas?
09-27-2004, 09:39 AM
#6
Also, just so you know, just got multimeter out, the 12v line is 12.33v so its not going underit
09-27-2004, 12:13 PM
#7
Vehicle: 2003 BMW M3
My Xenarc settings all go back to factory if it the screen loses power (like if I unplug the 12V from my Opus)
09-28-2004, 03:08 AM
#8
Weird, perhaps the liliput does the same after a certain ammount of time  any one else got problems?
09-28-2004, 11:48 AM
#9
Me have the same problem of the gain.
Does the under voltage perhaps cancel the data memorized in the inside eprom of Lilliput ?
09-28-2004, 11:58 AM
#10
I think this is the best explanation...kinda lame eh?
09-29-2004, 03:03 AM
#11
Just woundering if removin the power completely for 24 hours might do it? i havnt tried it runnin off the computers PSU properly yet, im just rememberin the problems i had with the lilliput egg, might of been due to engine cranking.
09-29-2004, 07:16 AM
#12
Usually to maintain the data they are used eprom or eeprom(different the second category) that also without power they also preserve them for many years, therefore that problem should not be us.
However' opening the lilliput doesn't seem me there and' any buffer battery, and not even particular condensers supercap that as backup is used.
I perhaps think an inside software problem of the lilliput.
Sorry for my bad English
Mauri
09-29-2004, 05:26 PM
#13
Vehicle: 98 Trans Am
I have that happen once in a while and I really think it has to do with cutting the power right as it enters standby. That may be the point when it writes to the EEPROM. Mine shows NO SIGNAL for about 2-3 seconds before the SDC cuts the power which is very close to when it would go into standby.
XPort 1.24 -GPS port splitter, logger, and USB device resume fix
| Thread Tools |
| Display Modes |
Linear Mode
