Old 12-12-2004, 12:39 AM   #106
PatO's Avatar
Talking
Wholy *****! It WORKED! 800x480! I'm using an ATI Radeon X800 (Powercolor) with the display hooked up as secondary. Using PowerStrip.
-- HORIZONTAL --
Front Porch: 32
Back Porch: 112
Sync Polarity: -
Sync Width: 80
Scan Rate: 37.646 kHz ( Can't be changed )
-- VERTICAL --
Front Porch: 61
Back Porch: 78
Sync Polarity: -
Sunc Width: 3
Refresh Rate: 60.524 HZ
Pixel Clock: 38.550
Someone should tell Xenarc to update their FAQ...
http://jeepmp3.home.comcast.net
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
Old 12-12-2004, 12:41 AM   #107
dingofarmer's Avatar
interesting enough, I just re-read my lili 7" manual and the res in question is not listed at all.
my old compaq armada 6500 pII300 actually would suport this res. too bad its so slow.
dingofarmer is offline   Reply With Quote
Old 12-12-2004, 01:01 AM   #108
Res Master
My timings worked for your Radeon? It's kick-butt huh! I love it and I'm sure you do too a lot bette than the alternate 800X600.
I didn't want to have to go for a third party program that's why I was leaning more towards the Nvidia because of the custom res option they offered I new sooner or later someone would have gotten it to work.
-- HORIZONTAL --
Front Porch: 32
Back Porch: 112
Sync Polarity: -
Sync Width: 80
-- VERTICAL --
Front Porch: 61
Back Porch: 78
Sync Polarity: -
Sunc Width: 3
Pixel Clock: 38.550
BIOSTAR M7NCG400 : AMD-M ATHLON XP 2400+ : VANTEC AIRFLOW : 512 MB 3200 RAM : XENARC 700TSVB : MSI 128MB DDR MX4000 : MONSTER 300 WATT INVERTER
redmage is offline   Reply With Quote
Old 12-14-2004, 09:13 AM   #109
fasternfaster's Avatar
Nvidia gf4 mx440 pci card works too!!! i installed into my m10000 and display #3 was the vga out, i just had to type in 800x480 and voila! and best of all its only 33 bux shipped to my door! woot! check on pricewatch
Status: 99%
hardware: 7"lilli mx440 pci,M10k/160GB/slim-slot DVD-CDRW/Hifonics ZEUS ZX8000,CNX1260,DConnex GPS,Powermate,usb WiFi
software: XP Home/Media Car/RoadRunner/IGuidance 2.0
Car: 2002 Ford Focus SVT
fasternfaster is offline   Reply With Quote
Old 12-15-2004, 07:56 PM   #110
Jackboot's Avatar
-- HORIZONTAL --
Front Porch: 32
Back Porch: 112
Sync Polarity: -
Sync Width: 80
-- VERTICAL --
Front Porch: 61
Back Porch: 78
Sync Polarity: -
Sunc Width: 3
Pixel Clock: 38.550
This is exactly what Xenarc has posted in their FAQ right now though...
http://www.xenarc.com/images/PowerStrip.jpg
Jackboot is offline   Reply With Quote
Old 12-15-2004, 09:02 PM   #111
Jesus Freak
antimatter's Avatar
Can you post some more details about your setup. Can you tell what exact card you bought and if you did any particular timing settings to get it to display correctly. Also does your lilliput report 800x480?
antimatter is offline   Reply With Quote
Old 12-15-2004, 09:06 PM   #112
Jesus Freak
antimatter's Avatar
Quote: Originally Posted by redmage
I did it a MSI MX4000-T128 ( Nvidia Geforce4 chipset ) that cost only 39.99 + tax at a local computer store without third-party software ( Powerstrip ) via the NView applet.
Is their any chance you know somebody with a lilliput and you could test it out? You gave the most complete review and i will get that exact card but i am curious if it will display correctly on the lilliput.
Old 12-16-2004, 12:59 PM   #113
@RedMage
what driver or applet did you use to set these settings? Did you use MSI drivers, or Nvidia drivers? Was this applet you used supplied by MSI or can every owner of a MX4000 card do the same thing you did?
Could you maybe post some pics of this applet?
thanx!!
Lazaru5 is offline   Reply With Quote
Old 12-16-2004, 01:05 PM   #114
Rub One Out
Motoko's Avatar
all nivida cards can do 800x480 even my onboard GPU
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 12-16-2004, 01:57 PM   #115
millec's Avatar
Quote: Originally Posted by Lazaru5
@RedMage
thanx!!
He is using Powerstrip. You can find it via google.
millec is offline   Reply With Quote
Old 12-16-2004, 04:17 PM   #116
Res Master
hehe, I'm not using powerstrip. That's why I was so intent on using Nvidia because they provide such functionality. The Nvidia applet is provided with all relatively recent Nvidia GPU's or IGP's. Go to Display Properties -> Settings -> Advanced -> Choose the GeForce or whatever Tab. You may, however, have to update your drivers. Only the newer versions of the Nvidia drivers add support for custom resolutions.
From the same dialog as above there should be a "Nvidia on the Internet" button, click and continue to download the current drivers. After there there should be a "Custom Resolution" section in the applet.
Old 12-16-2004, 06:43 PM   #117
I have it working with powerstrip but would prefer the nvidia software!! Only problem is I can add custom resolutions, but the advanced timings button greys out on any custom res.!!!
Any ideas???
matty_g is offline   Reply With Quote
Old 12-16-2004, 07:19 PM   #118
Jesus Freak
antimatter's Avatar
So anyone with a lilliput and an Nvidia card got everything work including having the lilliput osd display 800x480
Old 12-16-2004, 07:29 PM   #119
Camryputer's Avatar
I have a M6K and a Xenarc. Instead of fighting the system and adding a video card, I just set the resolution to 640x480 @ 60Hz. It looks great. The scaler inside the display does all the work.
Some benefits:
1) Performance: lower source resolution means the internal video frame buffer is smaller which translates to fewer pixels for the CPU to draw.
2) Font sizes: You don't have to select "extra large fonts" for things to be readable.
Camryputer is offline   Reply With Quote
Old 12-16-2004, 07:30 PM   #120
I needed the newest drivers. I found them and installed them. I copied your settings (weird way of entering them though, I had to type in the numbers backwards?!?) and it works!! Nice clear screen!
Sorry antimatter, I only have a Xenarc, so again no step further for you
The quest for no noise mp31500 General Hardware Discussion 26 04-02-2007 11:12 PM
Carputer Start-Up Quest. thepogcbr900rr Newbie 6 06-02-2004 12:57 AM
WTB: Quest for Glory Anthology naevity Classified Archive 0 02-03-2003 01:01 PM
The Quest For A New Avatar Aaron Cake Off Topic 8 10-05-2002 08:29 PM
The quest for serial comms! Bj General Hardware Discussion 0 12-04-2001 09:22 PM
