Old 10-03-2004, 02:58 PM   #1
Arathranar is on a distinguished road
10.4" SVGA (800x600) touch LCD $10
I found these of a local Seattle store (Vetco).
The problem is non-standard connectors. There is a 2 pin power cable with plug and a very small and thin 14 pin socket and 15 pin socket.
It is supposedly the screen from an Intermec 6640 tablet pc. I contacted them about whether it could be used as the screen for an auto pc and whether drivers were available. I got told it was proprietary so there was no way to get drivers. I've asked if that includes the potential vga socket (the 15 pin one) but so far have not received a response.
The body of the lcd is maybe a cm thick and it's only slightly bigger than the actual screen. Whilst it's too big to integrate into the dash, at $10 I'd be very happy to have it on a stand - maybe even directly in front of me since not a whole lot happens in the small amount of view just above my car bonnet that would end up obscured.
Any idea if its possible to determine if that 15 pin socket is VGA and, if so, the pin out to make a custom cable?
Arathranar is offline   Reply With Quote
Old 10-03-2004, 03:09 PM   #2
Forgot to say. It's also supposed to be a sunshine readable display...
Old 10-03-2004, 06:33 PM   #3
Don 944 LA's Avatar
Don 944 LA is on a distinguished road
crack it open and look on the PCB for any words or symbols in the etchings around the P/J..
Do they have any more, send me one and I'll check it out.
$10, can't go wrong
Don 944 LA is offline   Reply With Quote
Old 10-03-2004, 06:36 PM   #4
Yuriy's Avatar
Yuriy is on a distinguished road
They still have a few, I talked it over with Dan Marsh (another Seattle forumer) and we concluded that it's a sort of a laptop LCD which will need its separate controller to operate. Otherwise they would cost much more.
00 Saturn SL2, boosted @ 8 psi - CarDomain
Newest install - my quickest ever
My 2nd carputer - b4 I broke the touchscreen
My very first carputer - voted the most ghetto
Yuriy is offline   Reply With Quote
Old 10-03-2004, 06:44 PM   #5
It's very thick for just a laptop lcd panel. But the tablet pc it is supposed to be for was a ruggedized one. So maybe it is.
Old 10-04-2004, 01:25 PM   #6
Although all laptop lcds I've seen have not had an actual real socket for the signal - just something a ribbon cable would fit into. This has an actual 15 pin socket although it's very thin.
Old 10-04-2004, 02:48 PM   #7
sagekoala's Avatar
sagekoala is on a distinguished road
i have a couple on the way
i ordered a couple of them the other day. two of them for $28 shipped wasn't too bad and i figure it will give me something to mess around with until i get everything else for my project rounded up. the guy on the phone told me it was a Kyocera screen ... which somewhat confuses me because the only 10.4 tft they make is only 640*480 as far as i could tell. http://global.kyocera.com/prdct/ios/lcd/104_e.html might be it I'm not really sure if they ever told me a model number. but I'll update you guys if i find anything else out when i get them. from the people who have actually seen them at vetco do the picture on that webpage look anything like them??? if that is the screen it shouldn't be too hard to find a controler for it.
don't worry i know i usually don't make much sense
sagekoala is offline   Reply With Quote
Old 10-04-2004, 02:51 PM   #8
They has some other lcds that were something like 600x200 - I hope you aren't getting those.
Old 10-04-2004, 03:23 PM   #9
SnyperBob's Avatar
SnyperBob is on a distinguished road
You may want to look at Earth LCD to see if they offer a controller for the screen you have. I have run into the same problem - in terms of coming across cheap screens, but getting a controller and inverter costs $100-$200.
Usually it ends up not being worth it. But if you can make your own, that would rock. GL with that.
SnyperBob is offline   Reply With Quote
Old 10-05-2004, 06:22 PM   #10
sagekoala's Avatar
i got them today
Arathranar: nope, i got the correct ones.
SnyperBob: yeah but here is the way i look at it. even if the controller ends up costing me $200, i got a sunlight readable 10.4" touchscreen with a spare screen for $220. if it doesn't work I'm only out $20, i can acept that.
i don't know what the guy on the phone was smoking when i talked to him, it does say intermec at least twice on the screen. *runs off to find a controller* I"ll keep you guys updated on anything i find out.
update: (small step forward) using the model number convections off earthlcd's inventory list I've decided that dispite the fact that it says intermec in a couple place the panel is in fact a kyocera. the label on the back of the panel says ... KHB104SV2AC and earthlcd has a KHB104SV1ADG83 listed as a kyocera. i think tommorow i will shoot off an email to intermec, kyocera, and earthlcd to try to get more info. google has netted me nothing as of yet
Old 10-05-2004, 06:26 PM   #11
I've got my fingers crossed. I couldn't find anything in my searching but I'm still learning all about the wonders of LCDs and controllers.
I'm tempted to pick one up myself in case someone (probably not me!) can work it out. In the meantime I'm looking on eBay for 10.4" screens that I can get a controller for for less than an arm and a leg.
I actually have an old laptop that's basically a door stop which has a (not very bright) 10.4" lcd in it. I'm going to take it apart tonight and see if I can work out what controller I would need for it.
I also have a 15" lcd with controller board (it's a big board) with touch screen controller built in. Far too big for my car unfortunately!
Old 10-05-2004, 08:09 PM   #12
Yuriy's Avatar
Hmm, is there any way I could buy your 15" LCD with controller?
Old 10-05-2004, 08:15 PM   #13
It's not for sale right now as I may want to use it but I decide not to, I might well put it up for sale here or on eBay. The touch screen piece I've already used (that's originally why I purchased it - the lcd was supposed to be broken but worked just fine for me...) to replace the one on another screen that broken in transit. It comes in a damn ugly industrial metal case.
Old 10-05-2004, 08:25 PM   #14
Yuriy's Avatar
Heh, well, in case you ever wish to sell it, drop me a note
I'm considering a major upgrade.
Old 10-07-2004, 12:08 PM   #15
Yuriy's Avatar
Just a little bump. I'm rather interested in your progress and pictures of the device. I might pick one up myself it it's any good.
Help in need to get hold of 10.4" lcd johnemerson38 LCD/Display 4 10-05-2004 01:32 AM
Lilliput LCD UK supplier -touch screen in stock now 001 LCD/Display 5 02-28-2004 12:45 PM
FS: Touch 10.4" sharp VGA LCD .. Working with pics toto3 Classified Archive 13 03-01-2002 04:08 PM
10.4" lcd with digitalview interter + digitalview lcd controller Ces///M3 Classified Archive 5 01-22-2002 02:28 PM
10" vga lcd touch screen going for 350 us Mp3_Truck Classified Archive 1 06-16-2001 12:48 AM
